Posted by KBS Coatings on 12/10/2009 to
Customer Pictures
Frame Coater Kit was just the right amount for two coats top and bottom of tub on a 1965 Toyota Land Cruiser restoration. Great product; easy to use and self-leveling characteristic makes it look like I knew what I was doing!"- Mike J.
Tagged Products
$72.00
(158)
$126.00
(39)
(8)
Categories
Recent Posts
- Best Clear Coat for Metal: Prep Procedures and Application Tips for Long-Lasting Protection
- How to Fix a Rusting Truck Frame (And Stop It for Good)
- How to Seal a Metal Fuel Tank Inside and Out to Stop Rust and Extend Its Life
- How to Spot Treat Undercar Rust Before Winter | Rust Converter & RustSeal Guide
- How To Seal my Plastic or Polyethylene Gas Tank
- Do I Need to Use a Primer with High-Temperature Paint?
- How to Prepare Metal for Painting Using KBS Klean and RustBlast for Superior Adhesion
- Cold Galvanizing Compounds, Zinc-Rich Coatings, or RustSeal?
- How to Black Out Chrome Trim with Paint
- RustSeal Safety Colors for Industrial Equipment and Floor Markings
Archives
- August 2026
- July 2026
- June 2026
- May 2026
- April 2026
- March 2026
- February 2026
- January 2026
- December 2025
- November 2025
- October 2025
- September 2025
- July 2025
- June 2025
- March 2025
- February 2025
- January 2025
- November 2024
- February 2024
- January 2024
- October 2023
- September 2023
- August 2023
- July 2023
- June 2023
- February 2023
- January 2023
- December 2022
- November 2022
- October 2022
- August 2022
- July 2022
- March 2022
- January 2022
- September 2021
- August 2021
- June 2021
- May 2021
- March 2021
- January 2021
- June 2020
- May 2020
- April 2020
- March 2020
- February 2020
- December 2019
- April 2019
- March 2019
- February 2019
- October 2018
- March 2017
- October 2015
- April 2013
- March 2012
- February 2012
- July 2011
- December 2010
- December 2009
- October 2009
