Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
Application Guides Category
KBS Top Coater On An Engine Bay
Posted by KBS Coatings on 10/12/2018 to
Customer Pictures
Customer sent us pictures of
KBS Top Coater
in Battleship Grey. He used it to coat his engine bay.
Previous Post
Next Post
Have Questions? Click Here for Expert Support
Tagged Products
KBS Top Coater
KBS Top Coater is a single-component (1K), 100% UV stable top coat paint that bonds directly to bare steel and aluminum without a primer. Available in quart, gallon, and 5-gallon sizes across 18 colors in gloss and matte finishes; a gallon covers up to 700 sq. ft. in a single coat. It brushes, rolls, or sprays on without running or sagging, resists chemicals, and withstands temperatures up to 300°F.
(14)
More Info
Add Reply Comment
Name
Email
Body
Categories
Videos
Customer Pictures
News and Updates
Recent Posts
Introducing Relic Blue: A New Metallic Blue Color for KBS MAXX
How to Get Any KBS MAXX Color in the Finish You Want
How to Repair Trailer Frame Rust So It Doesn't Come Back
How to Handle Single-Component Moisture-Cured Urethane Coatings: Induction Time, Stirring Intervals, and Skinning Prevention
Best Clear Coat for Metal: Prep Procedures and Application Tips for Long-Lasting Protection
How to Clear Coat Taxidermy with DiamondFinish Clear
How to Apply Bedliner to Your Jeep Floor: Prep, Seal, and Protect
How to Fix a Rusting Truck Frame (And Stop It for Good)
How to Fix Rust on a Truck Frame and Stop Rust for Good
How to Fix a Rough, Faded, or Oxidized Water Slide - Restore Speed and Performance
How to Paint a Motorcycle Engine So It Doesn't Peel, Flake, or Burn Off
How to Paint an Axle Housing the Right Way - Prevent Rust and Peeling
How to Repair & Stop Car Floor Pan Rust | The Ultimate DIY Guide
How to Seal a Metal Fuel Tank Inside and Out to Stop Rust and Extend Its Life
How to Paint Rusty Exhaust Headers So the Finish Won’t Crack, Flake, or Peel
What’s the Most Durable Way to Seal Wood Exposed to Heavy Use and Harsh Conditions?
How Do You Stop and Prevent Rust on Steel UTV Skid Plates?
A Proper Body Repair Method That Keeps Rust from Coming Back
How to Prevent Boat Trailer Rust: A Step-by-Step Guide | KBS Coatings
How Can I Stop Rust and Make My Old Steel Fence Look New?
How to Spot Treat Undercar Rust Before Winter | Rust Converter & RustSeal Guide
How To Properly Open a Paint Can Preventing a Stuck Lid and How To Preserve Paint In The Can
How To Seal my Plastic or Polyethylene Gas Tank
How to Clear Coat Over Rust and Preserve the Patina Look
Do I Need to Use a Primer with High-Temperature Paint?
How to Prepare Metal for Painting Using KBS Klean and RustBlast for Superior Adhesion
How to Get Paint to Stick to Plastic: Step-by-Step Guide
Using Bed Liner on Rocker Panels, Doors, And Fenders for Protection
Garage Floor Makeover Using RustSeal and KBS MAXX
How to Remove Paint from Metal: A Complete Method Guide
Best Way to Store Paint and Coatings and Mix for Use
How to Black Out Chrome Trim with Paint
RustSeal Safety Colors for Industrial Equipment and Floor Markings
Using Nonconductive Coatings as Part of an EV Conversion
How To Paint A Concrete Floor and Seal a Concrete Floor
Rust Protection Using Clear Coat While Keeping a Rust Patina Look
How to Completely Seal a Rusty Fuel Tank
Clear Coat for Water-Based Paint and Coatings
Archives
June 2026
May 2026
April 2026
March 2026
February 2026
January 2026
December 2025
November 2025
October 2025
September 2025
July 2025
June 2025
March 2025
February 2025
January 2025
November 2024
February 2024
January 2024
October 2023
September 2023
August 2023
July 2023
June 2023
February 2023
January 2023
December 2022
November 2022
October 2022
August 2022
July 2022
March 2022
January 2022
September 2021
August 2021
June 2021
May 2021
March 2021
January 2021
June 2020
May 2020
April 2020
March 2020
February 2020
December 2019
April 2019
March 2019
February 2019
October 2018
March 2017
October 2015
April 2013
March 2012
February 2012
July 2011
December 2010
December 2009
October 2009
Get Answers to Your Questions
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
