We get an honest question asked all the time: “How can your coatings be hard and flexible? That does not make sense!”
When we started KBS Coatings, we utilized paint chemists that were on the forefront of coatings technology, and they helped us develop coatings that utilized innovative Cross-Linked Coatings Technology. Not only does this coatings technology (used in RustSeal, Tank Sealer, DiamondFinish Clear, KBS MAXX, KBS MAXX Clear, KBS Top Coater, Motor Coater) allow our coatings to adhere incredibly well to surfaces but this technology also allows our coatings to be insanely durable and hard while still being flexible enough to be applied to coil springs and leaf springs.
A diagram that shows what our coatings do is really nice but most people want to see this coatings technology in action. We get that.
Here is a video showing the toughness and flexibility of DiamondFinish Clear.
Also, here is a video showing the toughness and flexibility of RustSeal.
If you have a coatings application where you need a hard and durable coating that is flexible and adheres well, we have plenty of options for you. Please be sure to get some today!
Tagged Products
Categories
Recent Posts
Archives
- October 2026
- September 2026
- August 2026
- July 2026
- June 2026
- May 2026
- April 2026
- March 2026
- February 2026
- January 2026
- December 2025
- November 2025
- October 2025
- September 2025
- July 2025
- June 2025
- March 2025
- February 2025
- January 2025
- November 2024
- February 2024
- January 2024
- October 2023
- September 2023
- August 2023
- July 2023
- June 2023
- February 2023
- January 2023
- December 2022
- November 2022
- October 2022
- August 2022
- July 2022
- March 2022
- January 2022
- September 2021
- August 2021
- June 2021
- May 2021
- March 2021
- January 2021
- June 2020
- May 2020
- April 2020
- March 2020
- February 2020
- December 2019
- April 2019
- March 2019
- February 2019
- October 2018
- March 2017
- October 2015
- April 2013
- March 2012
- February 2012
- July 2011
- December 2010
- December 2009
- October 2009
