KBS Restoration Center - Application Guides
Every how-to guide we've published, organized by product and application type. Whether you're sealing a fuel tank, coating a frame, or finishing with DiamondFinish Clear, find the right guide below.
Application Tips
Chassis & Frame
Exhaust & High-Temp
Engine & Drivetrain
Application Tips
Guides for sealing and restoring metal and plastic tanks using the KBS Tank Sealer System.
- How to Completely Seal a Rusty Fuel Tank
- Simple Steps to Seal a Gas Tank with the KBS Coatings Tank Sealer System [Video]
- KBS Fuel Tank Sealer System Removes Rust and Restores the Inside of Your Tank to Like New
- Tip of the Month, Patience When Using Tank Sealer
How-to guides covering direct-to-rust application, surface prep, and real-world use cases for RustSeal.
- How to Paint a Rusty Farm Plow Without Sandblasting New
- What’s The Best Rust Preventive Coating?
- RustSeal Safety Colors for Industrial Equipment and Floor Markings
- Using Nonconductive Coatings as Part of an EV Conversion
- How To Stop Rust And Prevent Rust
- Marine Paint Needs to Have Toughness, Flexibility, and Durability
- RustSeal, Showing the Insane Durability and Flexibility of this Rust Preventive Paint [Video]
- Rust Prevention Products Used To Stop and Prevent Rust on Many Car Surfaces
- Lawn Mower Deck Paint Kit: Which Size You Need and How to Apply It
- RustSeal Rust Prevention Formulation Keeps KBS Coatings as the Leader of the Pack
- RustSeal Used for Rust Prevention on Coil Springs
- Seal Your Lawnmower Deck To Prevent Grass From Sticking
- RustSeal and KBS MAXX Used To Restore Old Truck
- RustSeal Used to Protect Zoo Enclosures from Animal Urine and Rust
- Apply RustSeal In Thin Coats
- Ray W. Talks About RustSeal
Full restoration workflows for frames, floor pans, springs, rockers, and body panels using the Frame Coater Kit and RustSeal system.
- Rubberized Undercoating: Why It Traps Rust and How to Apply It So It Does Not New
- The Best Way to Refinish a Rusty Truck Frame
- How to Paint an Axle Housing the Right Way (Prevent Peeling & Rust)
- How to Repair & Stop Car Floor Pan Rust, The Ultimate DIY Guide
- How to Paint Coil Springs and Leaf Springs So the Finish Doesn't Crack or Peel
- Using Bed Liner on Rocker Panels, Doors, and Fenders for Protection
- Car Frame Repair is Kept Free of Future Corrosion Using the KBS Ultimate Frame Coater Kit
- 1976 Honda Trail 70 Restored Using All KBS Products
- C40 Crew Cab Frame Coated with RustSeal
- The Motorcycle Frame Coater Kit Has Everything Needed to Remove Rust and Prevent Rust In The Future
- JavaTree on Jeepforum.com Talks About Frame Paint
- Mike Talks About The KBS Frame Coater Kit
Application guides for headers, exhaust pipes, manifolds, and engine bays using XTC (Xtreme Temperature Coating).
- How to Paint a Motorcycle Exhaust to Prevent Peeling, Flaking and Rust New
- How to Paint Rusty Exhaust Headers So the Finish Won't Crack, Flake, or Peel
- Automotive Exhaust Paint Can Extend the Life of Your Exhaust System
- Motorcycle Exhaust Coating Stops Corrosion, Looks Great, and is a Cost-Effective Solution
How-to guides for painting and restoring aluminum wheels, brake calipers, and rotors.
Proper prep is the foundation of every lasting coating. Guides for cleaning, derusting, etching, and stripping using KBS Klean, RustBlast, and KBS Strip.
- How to Detail Your Engine and Engine Bay with KBS Klean
- Can You Use Brake Cleaner Before Painting? The Best Way to Clean a Surface
- How To Prepare Metal Before Body Work To Prevent Future Rust
- Does Rust Converter Work? Converter, Reformer, and Full Removal Compared
- RustBlast is a Powerful Rust Remover, Keep Surface Wet
- KBS Coatings Introduces an ALL NEW Environmentally Friendly Powerful Paint Stripper
Application and use-case guides for DiamondFinish Clear, automotive, marine, wood, artwork, fishing lures, taxidermy, and more.
- Rust Protection Using Clear Coat While Keeping a Rust Patina Look
- Clear Coat for Water-Based Paint and Coatings
- What's the Most Durable Way to Seal Wood Exposed to Heavy Use and Harsh Conditions?
- Restoring a Wooden Countertop With DiamondFinish Clear
- Wood Clear Coat for Outdoor Use
- Headlight Clear Coat Damage Reduces Light Output
- Lure Makers Need A Quality Clear Coat
- DiamondFinish Clear Is The Ultimate Clear Coat for Fishing Lure Makers
- DiamondFinish Clear Is The Clear Coat To Add The Bling To Your Custom Artwork
- Candy Pigment and Flake Added To DiamondFinish Clear to Restore Jet Ski
- KBS Coatings Diamond Finish Clear for Freshening Up Gelcoat
- DiamondFinish Clear is an Ultra Durable 1K Clear Coat
- DiamondFinish Clear Video - Showing the Insane Durability and Flexibility of this Clear Coat [Video]
- Automotive Clearcoat with Superior Finish Quality, Durability and Ease of Use
- Flame Torched Copper Coated with DiamondFinish Clear
- Fishing Lure Dipped in DiamondFinish Clear
- Crankbait Clear Coated with DiamondFinish Clear
- DiamondFinish Clear on Fishing Lures
- DiamondFinish Clear on Vintage Table Lamps
Guides for applying BlackTop, Bed Renu, and bed liner coatings to truck beds, bumpers, rocker panels, Jeep floors, and textured surfaces.
Guides for coating engine blocks, engine internals, engine bays, and drivetrains using Motor Coater, RustSeal, and KBS MAXX.
- How to Restore an Engine Bay Without Removing the Engine New
- Engine Block Sealer and Engine Block Coating
- Engine Paint, What's Important for Best Performance?
- Motorcycle Engine Paint Makes Your Bike Look Great
- KBS Top Coater On An Engine Bay
How-to guides for painting and protecting plastic, composite, and hard-to-coat surfaces using Fusion FPP and Cavity Coater.
Guides for garage floor makeovers, concrete sealing, and wood shed floors using RustSeal, KBS MAXX, and DiamondFinish Clear.
- How to Paint and Seal a Concrete Floor with KBS Coatings
- Clear Concrete Sealer, How to Choose the Best Type for Your Project
How-to guides for protecting outdoor equipment, marine structures, and work vehicles against rust, moisture, and UV exposure.
- How to Fix a Rough, Faded, or Oxidized Water Slide, Restore Speed and Performance
- How to Stop and Prevent Rust on Your Boat Trailer: A Complete Guide
- How to Refinish a Rusty Snowplow
- Impressed with KBS Products On My 72 inch Mower Deck
General guidance for working with KBS coatings, from opening a can the right way to achieving a flawless finish with moisture-cured paints.
- How to Mix and Apply 2K Paint: It's Easier Than You Think New
- How to Brush Metallic Paint Without Streaks New
- How To Properly Open a Can of Paint and Then Store The Can of Paint for Future Use
- How to Achieve an Incredible Looking Finish When Applying A Moisture Cured Paint
- What Is Top Coat Paint? BlackTop, KBS Top Coater, and KBS MAXX Compared
- Coatings That Are Tough, Durable and Hard While Also Being Extremely Flexible
- Clear Coat: KBS Coatings DiamondFinish Clear Has Many Uses
Browse our complete How-To & Support center, or shop by product below.
