No, BlackTop Aerosol and standard (non-aerosol) BlackTop use different resin chemistry, with different heat ratings and hardness, even though both are single-stage, single-component black topcoats.
Aerosol vs. Standard BlackTop: Quick Facts
Standard resin: Moisture-cured urethane
Aerosol resin: Acrylic lacquer
Standard heat rating: 500°F
Aerosol heat rating: 300°F
Pick by priority. If maximum durability and heat resistance matter most, use standard BlackTop. If ease of use matters most, the aerosol is the faster, no-equipment option.
Standard, non-aerosol BlackTop (pint, quart, gallon, 5-gallon) is a moisture-cured 1K urethane. BlackTop Aerosol uses a different system: a professional-grade acrylic lacquer resin, chosen for fast, convenient spray-can application. The difference shows up in the published physical properties: standard BlackTop resists heat to 500°F and reaches 5H pencil hardness, while the aerosol is rated to 300°F and reaches 2H pencil hardness. Both are single-stage, single-component (no hardener, no clear coat needed) and both cure to a black finish, but they are not interchangeable products with identical performance.
Frequently Asked Questions: BlackTop Aerosol vs. Standard
No. They use different resin chemistry: standard BlackTop is a moisture-cured urethane, and BlackTop Aerosol is a professional-grade acrylic lacquer. Both are single-stage, single-component coatings, but their heat ratings and hardness differ.
Use standard, non-aerosol BlackTop. It resists heat to 500 degrees F and reaches 5H pencil hardness, both higher than the aerosol.
Use BlackTop Aerosol. It is rated to 300 degrees F and 2H pencil hardness, lower than the standard version, but it needs no spray equipment and is faster for small jobs and touch-ups.
Still have questions about which BlackTop to choose? Contact us for help.
