Use KBS #1 Thinner to clean up BlackTop, tools, and spray equipment before it dries; once BlackTop cures, no solvent will remove it.
Clean up before it dries. BlackTop cannot be removed by any solvent once cured, so clean your brush, roller, or spray gun immediately after use.
KBS #1 Thinner is the correct cleanup solvent for BlackTop, both for wiping down tools and for flushing a spray gun. If BlackTop gets on your skin, remove it right away with KBS #1 Thinner or lacquer thinner, followed by soap and water; once it stains, only time will fully remove it. Note that lacquer thinner is for skin cleanup only. Never use lacquer thinner to reduce or thin BlackTop itself; the directions specifically call for KBS #1 Thinner or xylene for thinning.
Frequently Asked Questions: BlackTop Cleanup
Use KBS #1 Thinner to clean tools, brushes, and spray equipment before BlackTop dries. Once cured, no solvent will remove it.
Remove it immediately with KBS #1 Thinner or lacquer thinner, followed by soap and water. If it stains, only time will fully remove it.
No. Lacquer thinner is only for removing BlackTop from skin. To thin or reduce BlackTop itself, use only KBS #1 Thinner or xylene.
Still have questions about BlackTop cleanup? Contact us for help.
