Yes, BlackTop bonds well over fully cured epoxy primer, DTM primer, and body filler.
BlackTop Over Primer or Filler: Quick Facts
Works over: Epoxy primer, DTM primer, body filler
Requirement: Primer or filler must be fully cured
Glossy surface? If the primer or filler is glossy or shiny, lightly scuff it with 320 grit before applying BlackTop for the best adhesion.
BlackTop applies directly over fully cured epoxy primers, DTM (direct-to-metal) primers, and properly cured body filler. Make sure the surface is dry and free of dust before you begin. If the primed or filled surface has a glossy sheen, scuff it lightly with 320 grit sandpaper first, since a smooth, shiny surface gives BlackTop less to grip.
Frequently Asked Questions: BlackTop Over Primer or Filler
Yes, BlackTop adheres well to fully cured epoxy primer, DTM primer, and body filler.
If the primed or filled surface has a glossy sheen, lightly scuff it with 320 grit sandpaper before applying BlackTop for enhanced adhesion. Clean and dry the surface before coating.
Yes. Follow the primer manufacturer's cure time before topcoating with BlackTop; coating over a primer that has not fully cured can trap solvents and affect adhesion.
Still have questions about primers and fillers under BlackTop? Contact us for help.
