Yes, KBS Coatings will mail you free, actual painted-out samples of Gloss, OEM Satin, and Flat Black BlackTop so you can see the true sheen before you buy.
Why request a sample? A screen can't show you true gloss level. Gloss measures 85 to 95%, OEM Satin measures 55 to 65%, and Flat measures 15 to 20%, and seeing the actual painted-out finish is the only reliable way to judge the difference before you commit to a size.
BlackTop comes in three sheens: Gloss Black, OEM Satin Black, and Flat Black. Because gloss level is hard to judge from a photo, KBS Coatings paints out real samples of each sheen and mails them to you at no cost, so you can compare them side by side before ordering a pint, quart, or larger size.
Frequently Asked Questions: BlackTop Sheen Samples
Yes, KBS Coatings provides real, painted-out samples of each BlackTop sheen so you can see the actual finish before you order.
No, painted-out sheen samples are free.
All three: Gloss Black (85 to 95% gloss), OEM Satin Black (55 to 65% gloss), and Flat Black (15 to 20% gloss).
Still have questions about BlackTop sheens? Contact us for help.
