By taking the proper steps to prepare and seal or prime the metal before body work (KBS Klean, RustBlast, RustSeal), future rust and possible pop off of the body filler can be prevented.
Read More
Can You Use Brake Cleaner Before Painting? The Best Way to Clean a Surface
We always recommend using KBS Klean to clean a surface before coating or painting. We formulated KBS Klean as an alternative to solvent based cleaners and degreasers which notoriously leave a residue on the surface which can cause surface tension. KBS Klean rinses clean and does not leave a residue.
Read More
Check out what happened when a customer added metal flake and candy pigment to DiamondFinish Clear to restore a jet ski. DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal or over other coatings.
Read More
