Answers to common Cavity Coater questions, from treating cavities that already have rust to spraying bulk Cavity Coater through a Schutz gun, protecting fuse and relay panels, and reusing the Cavity Wand. Type below to search, or browse the full list.
Cavity Coater Questions and Answers
Does Cavity Coater Stop Rust on Internal Cavities That Already Have Rust?
Yes. Knock off loose, scaly rust, make sure the surface is dry, and spray. It stops the rust from getting worse.
Can Cavity Coater Be Applied With an Undercoating Style Schutz Gun?
Yes. Thin bulk Cavity Coater 30 to 50 percent and spray at 90 to 150 PSI through the 48 inch wand.
Can I Reuse the Cavity Wand, or Is It a Single Use Item?
Reusable for many jobs. Invert the aerosol and spray 10 seconds to flush it after each use.
Can I Apply Cavity Coater to the Back Side of Fuse and Relay Panels?
Yes, it protects fuses and relays from corrosion. Turn electrical power off before you spray.
Still have a Cavity Coater question? Our team can help. Contact us here.
