Check out what happened when a customer added metal flake and candy pigment to DiamondFinish Clear to restore a jet ski. DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal or over other coatings.
Read More
DiamondFinish Clear is an Ultra Durable 1K Clear Coat
DiamondFinish Clear - 1K Automotive Clear Coat
DiamondFinish Clear is a crazy tough 1K Automotive Clear Coat that can be applied direct to a base coat.
DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and performs well in the toughest environments without yellowing, cracking or peeling.
DiamondFinish Clear is the obvious choice when looks and durability are what matters most!
For more information on DiamondFinish Clear click HERE.
Read More
1976 Honda Trail 70 Restored Using All KBS Products
Motorcycle Restoration
“1976 Honda trail 70 I restored using all KBS products. KBS Strip, RustBlast, RustSeal Black and Crazy Plum MAXX paint and DiamondFinish Clear... All products worked just like they said they would. MAXX and Clear sprayed perfect with high gloss and no runs ... As a matter of fact I couldn't make it run! All dried super hard! Then used KBS UnderCoat inside frame. On motor cases I used the silver Motor Coater and topped Motor Coater with the DiamondFinish Clear. I tell all my friends about how good KBS Products are!” -Robert T.
KBS Strip is a powerful aircraft strength paint remover that sprays as a semi gel coat for fast and easy coverage when stripping motorcycle parts. KBS Strip produces an even, unbroken film which seals and allows deep penetration through multiple layers of paint. KBS Strip will cling to vertical surfaces with minimal run or sag and offers low-odor technology. KBS Strip is the next generation of Paint Strippers containing no harmful Methylene Chloride.
KBS MAXX is a superior performance, two-component (2K), low VOC, low HAPs, permanently UV stable polyurethane topcoat that can be applied by brush, roller or sprayer making it ideal for motorcycle restorations. KBS MAXX is specifically designed for the indoor and outdoor applications including automotive, agricultural, fleet refinishing, marine, and heavy industrial equipment markets.
Motor Coater is easy to apply, offers superb coverage and yields a self-leveling professional looking finish brushed or sprayed. These engine enamels provide deep, rich pigmented colors for excellent coverage on motorcycle engines.
DiamondFinish Clear is a crazy tough Clear Coat ideal for motorcycles that can be applied Direct To Metal or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling making it ideal for motorcycle restoration.
Read More
Impressed with KBS Products On My 72 inch Mower Deck
Impressed with KBS Products On My 72" Mower Deck
Mower Deck Restoration
In these times of social distancing and stay at home orders, may of us are looking at projects around the house that may be long overdue. Many of our customers have turned to our paint products for restoring their equipment that may be rusty now or may rust down the road if not coated with a rust preventative coating.
Matthew P tells us: "I just wanted to say how impressed I've been with KBS products. I recently purchased a 72" finish mower that was mechanically sound but had lots of surface rust. I started with the underside of the deck and used the Frame Coater Kit with fantastic results. For the top of the deck I used the Klean/Blast/Seal process, then KBS Top Coater and then DiamondFinish Clear. I couldn't be happier with the results and I fully expect this thing to outlast me. Also worth mentioning is that KBS customer service is first-rate. They guided me on what products to use and delivery was super fast. Looking forward to more projects!”.
The KBS Products that he used are ideal for restoring a mower deck. The KBS Klean and RustBlast will prep the steel surface so that the rust is removed and the surface is etched leaving an anchor pattern on the surface of the metal that is ideal for paint adhesion. RustSeal prevents rust and is extremely durable which is a necessity for a mower deck on both the topside and the underneath.
The KBS Top Coater is a high solids UV stable coating that covers extremely well and leaves a beautiful finish that is very visible and also extremely durable. DiamondFinish Clear is a water clear coating that adds gloss and provides additional protecion and durability. Using the combination of all of those products left him with not only a beautiful finish but a finish that will be very easy to wash and clean after each use. The investment in a high quality coatings system will protect his equipment investment for years to come.
Read More
DiamondFinish Clear on Polished Wheels
DiamondFinish Clear Coat
DiamondFinish Clear is a 1K, water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
Highly polished wheels are perfect candidates to be clear coated with DiamondFinish Clear. DiamondFinish Clear will protect the wheels making them extremely easy to clean which is necessary because modern day cars and trucks generate a lot of brake dust that needs to be cleaned off so you can show off your highly polished wheels!
Read More
Flame Torched Copper Coated with DiamondFinish Clear
DiamondFinish Clear on Fishing Lure
“Flame painted copper is done with a torch. NO paint. We use the DiamondFinish Clear to seal the copper and keep the colors permanent.” -Randy A from Scottsdale, AZ
DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal (ferrous and non-ferrous) or over other coatings.
DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and will perform in the toughest environments without yellowing, cracking or peeling.
DiamondFinish Clear can be applied directly to a cured Automotive basecoat, Standard solid color paints, and Single Part or Two-Part paints. It can also be applied to Non-Ferrous metals including Aluminum, Alloys, Brass, Chrome and Copper.
Read More
Fishing Lure Dipped in DiamondFinish Clear
DiamondFinish Clear is used by crank bait and fishing lure makers all over the world. Because DiamondFinish Clear is a moisture cured urethane, DiamondFinish Clear performs extremely well in marine environments.
Fishing Lures and Crank Baits can be dipped in DiamondFinish Clear for a non-porous clear finish that will withstand the elements including being submerged in water.
Read More
C40 Crew Cab Frame Coated with RustSeal
Frame Paint for C40 Crew Cab
The KBS 3-Step Rust Prevention System was used to coat the frame of a C40 Crew Cab. RustSeal chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured, this superior coating is made even stronger by continued exposure to moisture. RustSeal is the ideal choice for all rusty car and truck frames.
Read More
DiamondFinish Clear on Vintage Table Lamps
“The Diamond Finish Clear coat is great! I strip and re-polish vintage table lamps for my desk sculptures. Not having a paint booth, I am amazed how well brush strokes absolutely disappear. I also needed the hardness and Durability qualities of it.” -Jim M.
Read More
KBS Top Coater On An Engine Bay
Customer sent us pictures of KBS Top Coater in Battleship Grey. He used it to coat his engine bay.
KBS Top Coater - Brushable Top Coat
Read More
RustSeal and KBS MAXX Used To Restore Old Truck
BlackTop - UV Stable Top Coat
“Your RustSeal and KBS MAXX Saved the Day!”
-Bud
Learn More or Grab Some RustSeal or KBS MAXX Today!
Read More
RustSeal Used to Protect Zoo Enclosures from Animal Urine and Rust
See how RustSeal stopped rust and urine damage in a zoo's indoor tiger enclosure, and what RustSeal needs for outdoor, UV-exposed metal.
Read More
BlackTop Looks Great on Snowmobile
“Painted with gun at buddy's body shop. Cheap, easy, incredible adhesion. Would not even wear on the running board spikes. Degrease, light scuff, tape sled off, paint, ride.”
- scrantonfirecat, Northeast PA
Learn More or Grab Some BlackTop Today!
Read More
Mike Talks about The KBS Frame Coater Kit
others - Stop Rust
others - Stop Rust
others - Stop Rust
Frame Coater Kit was just the right amount for two coats top and bottom of tub on a 1965 Toyota Land Cruiser restoration. Great product; easy to use and self-leveling characteristic makes it look like I knew what I was doing!"- Mike J.
Find the Frame Coater Kit – Chassis Paint Kit HERE.
Read More
Ray W. Talks About RustSeal
others - Stop Rust
others - Stop Rust
others - Stop Rust
"Yes I did have the chance to use your RustSeal! And I have to admit it is a bit better than the other two leading sellers. It was a hot day and humid too, since I'm in texas, and it went on nice but didn't tack up for over an hour. But within two hours it was a really nice finish and really secured the little rust area's very nicely!
I will be ordering another gallon within the next month or so when I go to finish the floors on my camaro. I have attached a photo or two for you.
Great product! Best yet!"
Read More
JavaTree on Jeepforum.com talks about Frame Paint
others - Stop Rust - Paint For Rust
others - Stop Rust - Paint Over Rust
"I wire wheeled the entire tub, used the three stage Chassis kit Chassis Paint Kit - KBS All-In-One Chassis Kit - KBS Coatings - prewash, metal prep, then applied paint with a brush/roller ... I painted the chassis, tub (inside & out), fenders, hood, bumpers and windshield frame. The main thing with this type of paint is to do ALL of the prep work, however painstaking it may be, and READ the instructions twice before starting. (That advice is for any of the rust preventive sealer paints.)"
Find out more about the All-In-One Chassis Coater Kit here: https://www.kbs-coatings.com/chassis-paint-kit.html
Read More
