Posted by KBS Coatings on 7/12/2022 to
Videos
This video shows the durability and flexibility of DiamondFinish Clear. DiamondFinish Clear is a tough Clear Coat that can be applied Direct To Metal or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
Tagged Products
$85.00
(4)
(382)
$44.00
(2)
$65.00
(6)
$214.00
(2)
Recent Posts
- Best Clear Coat for Metal: Prep Procedures and Application Tips for Long-Lasting Protection
- How to Fix a Rusting Truck Frame (And Stop It for Good)
- How to Seal a Metal Fuel Tank Inside and Out to Stop Rust and Extend Its Life
- How Do You Stop and Prevent Rust on Steel UTV Skid Plates?
- How Can I Stop Rust and Make My Old Steel Fence Look New?
- How to Spot Treat Undercar Rust Before Winter | Rust Converter & RustSeal Guide
- How To Seal my Plastic or Polyethylene Gas Tank
- Do I Need to Use a Primer with High-Temperature Paint?
- How to Prepare Metal for Painting Using KBS Klean and RustBlast for Superior Adhesion
- How to Remove Paint from Metal: A Complete Method Guide
- Cold Galvanizing Compounds, Zinc-Rich Coatings, or RustSeal?
- How to Black Out Chrome Trim with Paint
- RustSeal Safety Colors for Industrial Equipment and Floor Markings
- Using Nonconductive Coatings as Part of an EV Conversion
- How To Prepare Metal Before Body Work To Prevent Future Rust
- The Best Way to Clean a Surface Before Coating or Painting
- Candy Pigment and Flake Added To DiamondFinish Clear to Restore Jet Ski
- How To Paint A Concrete Floor and Seal a Concrete Floor
- The Best Way to Refinish a Rusty Truck Frame
- Rust Protection Using Clear Coat While Keeping a Rust Patina Look
- How to Completely Seal a Rusty Fuel Tank
- Clear Coat for Water-Based Paint and Coatings
- How to Refinish a Rusty Snowplow
Archives
- June 2026
- May 2026
- April 2026
- March 2026
- February 2026
- January 2026
- December 2025
- November 2025
- October 2025
- September 2025
- July 2025
- June 2025
- March 2025
- February 2025
- January 2025
- November 2024
- February 2024
- January 2024
- October 2023
- September 2023
- August 2023
- July 2023
- June 2023
- February 2023
- January 2023
- December 2022
- November 2022
- October 2022
- August 2022
- July 2022
- March 2022
- January 2022
- September 2021
- August 2021
- June 2021
- May 2021
- March 2021
- January 2021
- June 2020
- May 2020
- April 2020
- March 2020
- February 2020
- December 2019
- April 2019
- March 2019
- February 2019
- October 2018
- March 2017
- October 2015
- April 2013
- March 2012
- February 2012
- July 2011
- December 2010
- December 2009
- October 2009
