DiamondFinish Clear covers 400 square feet per gallon at one mil (25 micrometers) dry film thickness. However, you cannot achieve proper protection with a single coat. This guide covers coverage rates, coat requirements, and how to calculate the total amount you need for your project.
Shop DiamondFinish Clear
Plan for multiple coats: 400 sq ft per gallon assumes a single coat at 1 mil. Proper protection requires 2 minimum coats (2 mils total). Marine applications require 3+ coats.
Base Coverage Rate
DiamondFinish Clear has a theoretical coverage of 400 square feet per gallon at one mil (25 micrometers) dry film thickness. This is the coverage you can expect from a single, properly applied coat on an ideal surface.
Key word: "theoretical." Actual coverage depends on many variables including surface texture, application method (brush, roll, or spray), temperature, humidity, and skill level. Material loss during mixing and application is inevitable and must be considered when planning quantities.
Number of Coats Required
Coverage calculations mean nothing without understanding coat requirements:
General applications: A minimum of two full coats is required for proper protection. Two coats achieve approximately two mils (50 micrometers) dry film thickness, which is the standard for clear coat finishes.
Automotive applications: Standard automotive clear coat practice calls for 2 to 3 coats. A minimum of 2 is acceptable; 3 is preferred for show-quality results.
Marine applications: At least three full coats are required because marine environments expose coatings to UV, salt spray, and moisture stress. Three or more coats provide better durability and longer service life.
Coverage on Porous Surfaces
Bare wood, sandblasted metal, rough concrete, and other porous surfaces absorb more coating material:
Expect 50% less coverage on porous surfaces. Instead of 400 sq ft per gallon, plan on 200 sq ft per gallon. This is not a defect; it is because the coating is penetrating into the surface texture.
Buy extra material. If your project has a large porous component (bare wood, newly sandblasted steel, etc.), purchase additional product to account for the higher absorption.
Coverage Calculator by Size
Use this quick reference table to estimate how much area a single coat covers by container size (assuming ideal smooth surfaces):
Container SizeSingle Coat Coverage
4 oz12.5 sq ft
Pint (16 oz)50 sq ft
Quart (32 oz)100 sq ft
Gallon400 sq ft
5-Gallon Pail2,000 sq ft
For multiple coats: Multiply the single-coat coverage by the number of coats you plan to apply. For example, if you have a 200 sq ft project and plan 2 coats, you need: 200 sq ft x 2 coats = 400 sq ft coverage = 1 gallon of DiamondFinish Clear.
For porous surfaces: Multiply the single-coat coverage by 2 (to account for 50% absorption) and then by the number of coats. Example: 200 sq ft project on bare wood with 2 planned coats = 200 x 2 (porous factor) x 2 (coats) = 800 sq ft = 2 gallons.
Frequently Asked Questions About DiamondFinish Clear Coverage
How much area does DiamondFinish Clear cover?
DiamondFinish Clear has a theoretical coverage of 400 square feet per gallon at one mil (25 micrometers) dry film thickness. Actual coverage varies based on surface type and application method.
How many coats of DiamondFinish Clear do I need?
A minimum of two full coats is recommended to achieve at least two mils (50 micrometers) dry film thickness for proper protection. Marine applications require at least three coats.
Does DiamondFinish Clear cover less on bare wood?
Yes. On bare wood, rough, or sandblasted surfaces, expect up to 50 percent less coverage. Plan your quantities accordingly and always buy extra material for these porous surfaces.
How do I calculate the total amount of DiamondFinish Clear I need?
Multiply your project square footage by the number of coats planned (minimum 2). For porous surfaces, multiply by 2 to account for the 50 percent coverage loss. Refer to the single-coat coverage table in this guide.
Conclusion
Planning the right amount of DiamondFinish Clear starts with understanding that 400 sq ft per gallon assumes a single coat at 1 mil. Since proper protection requires a minimum of 2 coats (and 50% more material on porous surfaces), always plan accordingly and buy slightly extra. For complete product details, see the application directions.
Shop DiamondFinish Clear Still Have Questions? Contact Us
