Vehicles
Surfaces
Start here
Browse every guide →
Frame & chassis
Stop Rust systems
Try it first
Tank & clear coat
Find my kit →
Videos & How-To's
Product FAQs
Company
Resellers
Orders & shipping
Need A Long Term Storage Solution for DiamondFinish Clear?
KBS Paint Saver is a proven paint preserver that allows user friendly long term storing of DiamondFinish Clear in the original can. +More Info
Theoretical coverage at 2 mils is 400-450 sq.ft. per gallon. Recommended thickness of at least 4 mils would require at least two full coats. At least three coats recommended for marine applications. Material losses during mixing and application will vary and must be taken into consideration. Please expect up to 50% less coverage on bare wood, rough or sandblasted surfaces.
Need a Clear Coat with aFlat Finish?
Check OutKBS MAXX Clear!-OR-DiamondFinish Clear Aerosol!
DiamondFinish Clear - Showing the Insane Durability and Flexibility of this Clear Coat
DiamondFinish Clear is a 1K Clear Coat that Lays Out Like Glass
Watch as an oxidized fiberglass boat is easily cleaned up using KBS Klean getting the surface ready to clear coat the oxidized fiberglass with DiamondFinish Clear from KBS Coatings.
Watch as an oxidized fiberglass boat is easily clear coated using DiamondFinish Clear from KBS Coatings.
5.0
