DiamondFinish Clear adheres excellently to hard plastics and will not harm vinyl stickers or decals. It is ideal for protecting custom graphics, logos, vinyl decals, and decorative elements on plastic surfaces while adding durability and a brilliant high-gloss finish. This guide covers applications, preparation, and best practices.
Shop DiamondFinish Clear
Safe for vinyl and stickers: DiamondFinish Clear will not harm, dissolve, discolor, or lift vinyl decals or stickers. It seals and protects them while maintaining their appearance and adhesion.
Applying Over Hard Plastic
DiamondFinish Clear bonds reliably to hard plastics such as:
  • Hard hats and safety helmets
  • Plastic protective equipment
  • Rigid plastic equipment housings
  • Plastic lure bodies and components
  • Acrylic and polycarbonate panels
  • Other hard, rigid plastic surfaces
Preparation: Clean the plastic surface thoroughly with a mild soap and water solution or diluted KBS Klean to remove dirt, dust, and any mold release agent that may be present on new plastic. Allow to dry completely. You may lightly scuff with fine sandpaper (400-600 grit) for improved adhesion, but this is optional for most plastic surfaces.
Application: Apply thin, even coats of DiamondFinish Clear according to the application directions. The result is a durable, high-gloss protective coating that enhances the appearance of the plastic.
Sealing Vinyl Stickers and Decals
DiamondFinish Clear is ideal for protecting vinyl stickers, custom decals, graphics, and logos. It will:
  • Seal and protect the sticker from dirt, moisture, and UV damage
  • Enhance the gloss and color saturation of the vinyl graphics
  • Not harm the vinyl adhesive or cause lifting or bubbling
  • Create a tough, durable protective layer over the graphics
Important: Do not attempt to scuff or sand vinyl stickers. The sticker surface is delicate. Simply clean the area surrounding the stickers (and the stickers themselves if needed) with a soft, lint-free cloth and allow to dry. Then apply DiamondFinish Clear carefully over the sticker area using thin, overlapping passes. Avoid over-applying or puddling on the sticker edges.
Common Applications
DiamondFinish Clear on plastic and vinyl is used for:
Lure dipping: Clear coating fishing lures (hard plastic, balsa, or composite lures with vinyl or decal details). DiamondFinish Clear provides a clear, glossy, durable topcoat that protects the lure and enhances its appearance in the water.
Helmet graphics: Protecting custom graphics, logos, and vinyl decals on motorcycle helmets, racing helmets, or other safety helmets. DiamondFinish Clear adds gloss and durability without harming the vinyl graphics.
Equipment labeling: Sealing labels, logos, and vinyl decals on hard plastic equipment, tool cases, or portable machinery. The clear coating protects the decal and adds a professional look.
Custom artwork protection: Protecting custom vinyl graphics or painted designs on hard plastic surfaces. DiamondFinish Clear locks in the color and adds UV protection.
Read the Application Directions
Frequently Asked Questions About DiamondFinish Clear on Plastic and Vinyl
Will DiamondFinish Clear adhere to hard plastic?
Yes. DiamondFinish Clear is ideal for clear coating hard plastics like hard hats, plastic helmets, protective equipment, and other rigid plastic items. It adheres well and provides a durable, high-gloss protective coating.
Can DiamondFinish Clear be applied over vinyl stickers and decals?
Yes. DiamondFinish Clear is ideal for sealing and protecting vinyl stickers, decals, and vinyl graphics. It will not harm the vinyl or adhesive, and it creates a protective, high-gloss finish over the sticker.
Will DiamondFinish Clear damage vinyl decals or stickers?
No. DiamondFinish Clear will not harm, dissolve, or damage vinyl stickers or decals. It is specifically formulated to adhere to and protect these materials without causing adhesion loss, bubbling, or discoloration.
What applications use DiamondFinish Clear on plastic and vinyl?
Common applications include clear coating hard hat graphics, protecting custom vinyl decals on helmets or equipment, sealing artwork or logos on plastic surfaces, dipping fishing lures with vinyl or plastic components, and protecting custom graphics on protective gear.
Conclusion
DiamondFinish Clear is the go-to choice for protecting hard plastics and vinyl stickers. It bonds reliably, won't harm vinyl or adhesives, and creates a brilliant, protective high-gloss finish. From fishing lures to helmet graphics to equipment labels, DiamondFinish Clear delivers both protection and beauty. For complete application details, see the application directions.
Shop DiamondFinish Clear Still Have Questions? Contact Us
