Yes, DiamondFinish Clear can be applied over other coatings, including base coats, primers, and existing topcoats. The secret is thorough surface preparation. This guide covers the exact steps to clean, scuff, and prepare an existing coating for DiamondFinish Clear.
Shop DiamondFinish Clear
Critical rule: The existing coating must be fully cured before you apply DiamondFinish Clear. If you are unsure, allow extra cure time. Applying over uncured paint risks adhesion failure, lifting, or wrinkling.
Full Cure Requirement
Before you even think about scuffing or cleaning, the underlying coating must be completely and fully cured. This is non-negotiable. Applying DiamondFinish Clear over paint that is not fully cured can cause:
  • Adhesion failure (the clear coat peels or flakes off)
  • Lifting or wrinkling of the base coat
  • Trapped solvents that continue to gas out and create bubbles
  • Compromised final finish quality
If you are working with a custom paint or an unfamiliar product, check the technical data sheet or contact the paint manufacturer for full cure times. When in doubt, wait longer rather than rushing the application.
Surface Preparation Steps
Once the underlying coating is fully cured, follow these exact steps:
  1. Mix the cleaning solution. Dilute KBS Klean at a ratio of 10 parts warm water to 1 part KBS Klean. For example, 10 ounces of water to 1 ounce of KBS Klean.
  2. Clean the surface thoroughly. Use the diluted solution and a clean cloth or soft brush to remove all dirt, dust, wax, and contaminants from the base coat. Pay special attention to crevices and edges.
  3. Scuff the surface. Use 600 to 1200 grit sandpaper to lightly scuff the entire surface. This creates mechanical tooth for adhesion. Do not over-sand; a light scuff is sufficient.
  4. Clean again. Repeat the cleaning process with the diluted KBS Klean solution to remove all sanding dust and any remaining contaminants.
  5. Rinse thoroughly. Use clean water to rinse the surface completely. Make sure no cleaning residue remains.
  6. Allow to dry completely. Let the surface dry fully before applying DiamondFinish Clear. This may take 30 minutes to an hour depending on temperature and humidity.
  7. Apply DiamondFinish Clear. Once the surface is clean and dry, apply DiamondFinish Clear according to the application directions.
Why Scuffing Matters
Scuffing the base coat with 600-1200 grit sandpaper serves two critical purposes:
Mechanical adhesion: Scuffing creates tiny peaks and valleys on the surface. When DiamondFinish Clear flows onto this roughened surface, it locks into those micro-imperfections, creating a much stronger mechanical bond than it would on a smooth, glossy surface.
Removes gloss and contaminants: Many base coats and topcoats have a glossy finish that prevents good adhesion. Scuffing removes that gloss and also breaks up any surface contamination (wax, polish, oxidation) that you might have missed during cleaning.
Do not over-sand. You only need to dull the surface gloss slightly. Heavy sanding can remove too much material and change the color or sheen of the base coat.
Shop KBS Klean
Frequently Asked Questions About DiamondFinish Clear Over Base Coats
Can DiamondFinish Clear be applied over other coatings?
Yes, DiamondFinish Clear can be applied over other coatings that are fully cured. The key is proper surface preparation: clean, scuff, and dry thoroughly before application.
What is the proper way to prep a base coat for DiamondFinish Clear?
Clean the surface with KBS Klean diluted 10 parts warm water to 1 part KBS Klean. Scuff with 600 to 1200 grit sandpaper. Repeat the cleaning process, then rinse thoroughly and allow to completely dry before applying DiamondFinish Clear.
Why do I need to scuff the base coat?
Scuffing with 600-1200 grit sandpaper creates mechanical tooth on the existing coating surface. This gives DiamondFinish Clear something to grip and improves adhesion and bond strength.
Can I apply DiamondFinish Clear over any existing paint or coating?
As long as the existing coating is fully cured and properly prepared with KBS Klean and scuffing, DiamondFinish Clear will adhere to most surfaces. Always test a small, inconspicuous area first if you are unsure.
Conclusion
DiamondFinish Clear is an excellent choice for protecting and enhancing existing coatings. The three-step prep process (clean with diluted KBS Klean, scuff 600-1200 grit, clean again and dry) takes just a few minutes but makes all the difference in adhesion and finish quality. For complete application details, see the application directions.
Shop DiamondFinish Clear Shop KBS Klean Still Have Questions? Contact Us
