DiamondFinish Clear can be applied over fully cured lacquer and enamel paint, whether solvent-based or water-based. The critical requirement is complete cure. This guide covers cure times, preparation, and best practices for applying DiamondFinish Clear over these common automotive and industrial finishes.
Applying Over Lacquer
Lacquer is a fast-drying, solvent-based finish common in automotive and furniture applications. DiamondFinish Clear bonds excellently to cured lacquer.
Typical lacquer cure time: Lacquer may feel dry to the touch within 30 minutes to an hour, but full cure (where all solvents have evaporated and the film has hardened completely) typically takes 24 to 48 hours depending on temperature, humidity, and film thickness.
Preparation: Follow the same prep steps as for any other coating: clean with diluted KBS Klean, scuff lightly with 600-1200 grit sandpaper, clean again, and dry thoroughly before applying DiamondFinish Clear.
Compatibility: Both solvent-based and water-based lacquers are compatible with DiamondFinish Clear, as long as they are fully cured.
Applying Over Enamel
Enamel is a harder, more durable finish than lacquer and is widely used in automotive, industrial, and household applications. DiamondFinish Clear is fully compatible with cured enamel.
Typical enamel cure time: Enamel is slower-drying than lacquer. Full cure typically takes 48 to 72 hours or longer depending on temperature, humidity, and film thickness. Some enamels may require even longer cure times. Always check the enamel product data sheet or manufacturer instructions for specific cure windows.
Preparation: Clean with diluted KBS Klean, scuff lightly with 600-1200 grit sandpaper to remove gloss, clean again, and allow to dry completely. This breaks any surface gloss and removes contaminants that could interfere with adhesion.
Compatibility: Both solvent-based and water-based enamel formulas are compatible with DiamondFinish Clear when fully cured.
Cure Time Requirements
The most common mistake is applying DiamondFinish Clear too soon. Here is a quick reference:
| Paint Type | Typical Full Cure Time | Note |
| Lacquer (solvent-based) | 24-48 hours | Faster drying; feels dry within hours but needs full cure |
| Lacquer (water-based) | 24-48 hours | Similar cure to solvent-based; check product data sheet |
| Enamel (solvent-based) | 48-72 hours | Slower drying; full cure is critical |
| Enamel (water-based) | 48-72 hours or more | Variable; always check manufacturer instructions |
These are general guidelines. If you are unsure, check the technical data sheet for the specific lacquer or enamel you are using. When in doubt, allow 72 hours or more before applying DiamondFinish Clear.
Frequently Asked Questions About DiamondFinish Clear Over Lacquer and Enamel
Can DiamondFinish Clear be applied over lacquer paint?
Yes. DiamondFinish Clear can be applied over fully cured lacquer paint. Both solvent-based and water-based lacquers are compatible, as long as the lacquer is completely cured before application.
Can DiamondFinish Clear be applied over enamel paint?
Yes. DiamondFinish Clear can be applied over fully cured enamel paint. Both solvent-based and water-based enamel formulas are compatible, as long as the enamel is completely and fully cured.
What does fully cured mean for lacquer and enamel?
Fully cured means the paint has hardened completely and no solvents are escaping from the coating. This typically takes 24 to 48 hours for lacquer and 48 to 72 hours for enamel, depending on temperature and humidity. When in doubt, allow additional cure time.
Why is full cure so important before applying DiamondFinish Clear?
Applying DiamondFinish Clear over paint that is not fully cured can cause adhesion failure, lifting, or wrinkling. The solvents still escaping from the base coat can prevent DiamondFinish Clear from bonding properly. Full cure ensures a strong, lasting bond.
Conclusion
DiamondFinish Clear is an excellent choice for adding durability and high gloss to lacquer and enamel finishes. The key is patience: allow full cure (24-72 hours depending on the base paint), then prepare properly with cleaning and light scuffing before applying. The result is a beautiful, long-lasting finish. For complete application details, see the application directions.
