To spray DiamondFinish Clear, thin it 10 to 15 percent with KBS #1 Thinner or xylene only. That is normally enough, and you can go up to 30 percent when conditions call for it.
No fast thinners: DiamondFinish Clear needs a slower evaporating solvent than standard paint thinner. Fast evaporating solvents make it dry too quickly and cause orange peel, dry spray and poor flow-out.
How Much to Thin DiamondFinish Clear for a Spray Gun
10 to 15 percent is normally adequate. For a quart (32 ounces), that is 3.2 to 4.8 ounces of thinner. In high heat or humidity, thin more than normal to avoid gassing and micro-bubbling, up to 30 percent.
What to Thin It With
KBS #1 Thinner is the recommended thinner and is made for KBS topcoats. Xylene has a similar evaporation rate and works as a substitute. Do not use anything else.
Spray Gun Settings
| Equipment | Pressure | Tip |
| HVLP | 25 to 35 psi air, 25 to 35 psi fluid | 1.0 to 1.6 mm |
| Conventional | 35 to 55 psi air, 15 to 20 psi fluid | 1.0 to 1.6 mm |
| Conventional electrostatic | 40 to 60 psi air, 15 to 20 psi fluid | 1.0 to 1.6 mm |
| Air assisted airless | 15:1 ratio pump or larger at 80 to 100 psi, atomizing air adjusted as needed | 0.009 to 0.013 in |
| Airless | 1500 psi minimum | 0.009 to 0.011 in |
Use a medium viscosity cap on conventional and HVLP guns. The paint spraying guidelines cover gun setup and spray defects.
Spraying Tips
- Wear an air supplied respirator or a NIOSH/MSHA approved organic vapor particulate respirator, plus eye protection.
- Stir gently and thoroughly before thinning. Do not shake the can.
- Spray thin covering coats, a minimum of two at 2 mils dry film thickness each.
- Recoat once the last coat is dry to the touch and takes no fingerprint, typically 2 to 4 hours.
- Clean the spray gun with KBS #1 Thinner immediately after use. Once DiamondFinish Clear cures, no solvent will remove it.
- In a spray booth, cure with low air flow and moderate temperatures. Do not use UV or bake lights.
Frequently Asked Questions: Thinning Clear Coat for Spraying
It depends on the coating. For DiamondFinish Clear, 10 to 15 percent KBS #1 Thinner or xylene is normally adequate, and it can be thinned up to 30 percent.
With DiamondFinish Clear, apply a minimum of two thin covering coats at 2 mils dry film thickness each, and at least three on marine, industrial or constantly wet surfaces. Make sure the paint under it is fully cured first.
Yes for DiamondFinish Clear. The directions call for a 1.0 to 1.6 mm tip on conventional and HVLP guns, and 1.3 mm sits inside that range.
KBS #1 Thinner, which is made for KBS topcoats. Xylene has a similar evaporation rate and works as a substitute. Use nothing else.
No. DiamondFinish Clear needs a slower evaporating solvent than standard paint thinner. Fast evaporating solvents make it dry too quickly, which leads to orange peel, dry spray and poor flow-out.
With an HVLP gun, 25 to 35 psi. With a conventional gun, 35 to 55 psi air pressure and 15 to 20 psi fluid pressure.
Still have questions about spraying DiamondFinish Clear? Contact us for help.
