Rust Prevention Paints
Rust Converter & Repair
Converter or RustSeal? Converter treats existing rust. RustSeal is a permanent barrier coating that keeps it from coming back. Compare the two →
Engine & High-Temp Paint
Tank Sealers
Supplies, Guns & Gloves
Vehicles
Surfaces
Start here
Browse every guide →
Frame & chassis
Stop Rust systems
Try it first
Tank & clear coat
Find my kit →
Videos & How-To's
Product FAQs
Company
Resellers
Orders & shipping
The Frame Coater Kit is KBS Coatings' complete 3-step rust prevention system — KBS Klean to degrease, RustBlast to etch and neutralize rust, and RustSeal to permanently seal out rust and corrosion. One quart kit covers a full-size car or truck frame, or any 50 sq. ft. surface with 2 coats of professional-grade rust protection. Available in multiple colors. Factory direct — detailed instructions included.
The Frame Coater Kit includes everything you need to clean, prep, and apply two full coats of RustSeal on up to a 50 square foot area — enough to cover a full-size car or truck frame.
RustSeal chemically bonds to bare metal to form a permanent, moisture-resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured, it is made even stronger by continued exposure to humidity and moisture — the conditions that cause other coatings to fail.
RustSeal is also highly resistant to aggressive chemicals including acids, alkalis, salts, solvents, oils, fertilizers, and refined petroleum products.
View the RustSeal Color Guide for help choosing the right finish.
Gloss Levels: Galvanized (30%), Satin Black (70-75%), Gloss Black (85-95%), Other Colors (75-85%)
Quart of KBS KleanIndustrial Strength Degreaser
Quart of RustBlastRust Remover & Metal Etch
Quart of RustSealPermanent Moisture-Cured Coating
Application ToolsNitrile Gloves, Brushes, & Stir Stick
Detailed GuideComplete Step-by-Step Instructions
Doing more than just the frame? Want to coat the whole underside of your vehicle?
► Check out the Large Frame Coater Kit!
A comprehensive guide to identifying and stopping corrosion permanently.
Watch RustSeal withstand extreme stress without cracking or peeling.
How to prepare surfaces before body work to prevent future rust bubbles.
Learn the best spots on your vehicle to apply rust protection.
A step-by-step video on removing rust and painting mower decks.
Why RustSeal’s formulation remains the industry standard.
5.0
