Answers to common Fusion SEP self-etching primer questions, from what goes over it and how to prime brass to priming over factory paint. Type below to search, or browse the full list.
Fusion SEP Questions and Answers
After Fusion SEP, Can I Use an Enamel Paint and Clear?
Yes. Topcoat with an enamel like Motor Coater after 1 hour, then clear it after at least 7 days.
Can I Apply Fusion SEP Over Factory Paint and Then Coat It?
Yes. Clean with KBS Klean, rinse, dry, apply one thin coat, and topcoat after 1 hour.
Does Fusion SEP Etch and Prime Brass?
Yes. It primes brass, copper, bronze and aluminum. Clean with KBS Klean at 25 to 1 first.
What Color Is Fusion SEP?
Medium grey, one color only, so you can see exactly where you have primed.
Working with flexible plastic? Fusion SEP is for rigid surfaces. See the Fusion FPP questions, or contact us here with any Fusion SEP question.
