Yes. KBS Klean is a water based cleaner and degreaser that rinses away completely, which is exactly what you want before spraying paint. Solvent based cleaners can leave an invisible residue that interferes with paint adhesion and appearance. Clean with KBS Klean, rinse thoroughly, let the surface dry, then etch bare metal with RustBlast before you paint.
Cleaning Metal Before Paint: Quick Facts
Leaves behind: nothing, it rinses away with water
Avoid: solvent based cleaners, invisible residue risk
Wash time: 5 to 10 minutes for general cleaning
Next step on metal: RustBlast etch before painting
Cleaning is not the last prep step on bare metal. Metal surfaces cleaned with KBS Klean should be treated with RustBlast before painting to ensure proper adhesion. Degreasing removes contamination; etching gives the paint something to grip.
Why a Water Based Cleaner Instead of a Solvent
The RustBlast directions put it plainly: clean with a water based cleaner and degreaser like KBS Klean, and avoid any solvent based cleaners, because they can leave an invisible residue which can interfere with paint adhesion and appearance. Invisible is the operative word. You cannot inspect your way past it, and you find out about it after the paint is on.
Acetone, mineral spirits and lacquer thinner all fall in that category for this purpose. They evaporate, but what was dissolved in them is redeposited on the panel as the solvent flashes off.
The Cleaning Step, Start to Finish
  1. Dilute with hot water at the ratio that matches the soil level. See the dilution ratios.
  2. Shake well, then apply the solution liberally.
  3. Wash the surface for 5 to 10 minutes, or as long as needed to produce a clean surface. Use a bristle brush or scouring pad on stubborn areas.
  4. Do not let KBS Klean dry on the surface. Rinse thoroughly with water.
  5. Let the surface dry completely.
  6. On bare metal, treat with RustBlast before painting.
Wear protective rubber gloves and safety glasses at all times.
Heavy Grease and Oil
For heavy contamination, use the heavily soiled ratio of 1 part hot water to 1 part KBS Klean, and extend the contact time. Extended soaking of up to 24 hours or more may be necessary on badly contaminated parts. Retreat with fresh solution as needed until the surface is clean rather than trying to do it in one pass.
Hotter water does more for you here than a richer mix. The warmer the water used, the more effective and powerful the cleaning action.
Frequently Asked Questions: Cleaning Metal Before Painting
Wash it with a water based cleaner and degreaser diluted in hot water. For heavy grease use 1 part hot water to 1 part KBS Klean, wash for 5 to 10 minutes or longer, use a bristle brush on stubborn areas, then rinse thoroughly and let the surface dry.
A water based cleaner and degreaser, not a solvent. Solvent based cleaners can leave an invisible residue that interferes with paint adhesion and appearance. KBS Klean rinses away with water and leaves nothing behind.
Yes. It is a cleaner and degreaser that leaves a clean surface for painting and does not leave the residue that solvent based cleaners can leave. On bare metal, follow it with a RustBlast etch before painting.
Those are solvent based cleaners, and the directions specifically say to avoid them for paint prep because they can leave an invisible residue that interferes with adhesion and appearance. Use a water based cleaner and degreaser instead.
On bare metal, yes. The directions state that metal surfaces cleaned with KBS Klean should be treated with RustBlast before painting to ensure proper adhesion. Cleaning removes contamination, etching creates the profile.
Let it dry completely before the next step. Drying it quickly rather than letting it air dry slowly also minimizes flash rust on bare steel.
Still have questions about cleaning metal before paint? Contact us for help.
