KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents & hazardous chemicals for preparing your paint job with a clean surface.
KBS Klean is Step #1 in the KBS 3-Step Rust Prevention System and the KBS 3-Step Tank Sealing System.
KBS Klean is a powerful cleaner that deeply penetrates and removes stubborn soil from most surfaces without leaving harmful residues or emitting noxious fumes.
KBS Klean is perfect for the home, garage, or plant to effectively remove dirt, grime, oils, lubricants, grease, waxes, scum, algae, road film, and other contaminants.
KBS Klean may be used in pressure washing equipment to produce the rapid penetration of many layers of accumulated build up. Cleaning projects have never been easier! Satisfaction guaranteed!
KBS Klean Directions
Application Flow Chart
How-To's Using KBS Klean
5.0
