Yes. KBS Klean is highly effective at cleaning and neutralizing salt residue. It is a concentrated water based cleaner and degreaser, and removing harmful road salts is one of the things it does best. On a frame or underbody that has seen winter roads, this is the step that has to happen before anything else, because salt left under a coating keeps working.
Why Salt Is a Different Problem From Grease
Grease sits on the surface and blocks adhesion. Salt does that too, but it also draws moisture and keeps the corrosion reaction going after the part is painted, which is why a frame can be coated and still rust from the inside of the coating outward. Getting the chloride off the metal is the point of the cleaning step on any vehicle that has been driven through winter.
How to Do It
- Dilute with hot water. A salted underbody is usually the heavily soiled case at 1 part hot water to 1 part KBS Klean, or 5 to 1 for moderate accumulation. See the dilution ratios.
- Shake well, apply liberally, and wash for 5 to 10 minutes or as long as needed. Use a bristle brush on caked areas.
- Work in sections so nothing dries. Do not allow KBS Klean to dry before rinsing.
- Rinse thoroughly with water. On a frame, rinse more than you think you need to; salt hides in seams, box sections and behind brackets.
- Let the surface dry completely.
KBS Klean may be used in power washing equipment, which is worth knowing for an underbody where reach is the hard part.
Then Etch, Then Coat
Metal surfaces cleaned with KBS Klean should be treated with RustBlast before painting to ensure proper adhesion. On a salted frame with rust already started, that is the normal sequence anyway: KBS Klean to clean, RustBlast to etch and leave a zinc phosphate base, then two coats of RustSeal at 2 mils each.
Protective Equipment
Wear protective rubber gloves and safety glasses at all times when using this product. Underbody work means working overhead, so eye protection matters here more than on a bench.
Frequently Asked Questions: KBS Klean and Road Salt
Still have questions about removing road salt with KBS Klean? Contact us for help.
