Mix the KBS MAXX or KBS MAXX Clear Base first with a mechanical mixer on a variable speed drill until it is smooth, then measure 3 parts Base to 1 part MAXX Activator and mix again. Both are high solids coatings, and a drill-driven mixer brings all the components back together in a way a stir stick may not. That is what gives you the best looking and most durable finish.
Mixing KBS MAXX: Quick Facts
Mix ratio: 3 parts Base to 1 part MAXX Activator
Mixer: KBS Hurricane Paint Mixer or similar, on a variable speed drill
Pot life: doubles in viscosity in 30 minutes
Reducer: none needed; KBS #1 Thinner or xylene if required
Never reduce with lacquer thinner. Lacquer thinner is not compatible with KBS MAXX or KBS MAXX Clear as a reducer and will compromise the finish. It is fine for equipment cleanup only.
Step by Step
  1. Mix the Base, color or clear, thoroughly with the KBS Hurricane Paint Mixer or a similar mixing blade on a variable speed drill until it is smooth and uniform.
  2. In a mixing cup, measure 3 parts of the mixed Base. A graduated cup such as the KBS Paint Mixing Cup makes this easy.
  3. Add 1 part MAXX Activator.
  4. Mix thoroughly again with the mechanical mixer.
  5. If your equipment calls for reduction, add KBS #1 Thinner or xylene, 5 to 10 percent for spraying, and mix again. Strain through a 100 micron filter before it goes in the gun.
  6. Apply it within the pot life. Do not return mixed material to the original can.
Why Mechanical Mixing Matters
KBS MAXX is about 60 percent solids by volume. That is a big part of why it is so durable, and it also means the solids settle in the can. The KBS MAXX directions call mixing well the key to long term durability and appearance. A mixing blade on a drill pulls everything off the bottom and back into suspension, and the Hurricane Paint Mixer does it in as little as 10 seconds.
KBS MAXX and KBS MAXX Clear Mix the Same Way
Both use the same MAXX Activator, the same 3 to 1 ratio, and the same 30 minute pot life. The KBS MAXX directions and KBS MAXX Clear directions give the full application details for each. Each KBS MAXX kit is packaged at 3 to 1 already: a quart is 24 oz of Base with 8 oz of Activator.
Blending two KBS MAXX colors into a custom shade? Blend the Base colors first and add the Activator last. See blending KBS MAXX colors.
Frequently Asked Questions: Mixing KBS MAXX
Mix the KBS MAXX Base thoroughly with a mechanical mixer, such as the KBS Hurricane Paint Mixer on a variable speed drill, until it is smooth. Then measure 3 parts Base to 1 part MAXX Activator and mix thoroughly again with the mechanical mixer.
The same way. Mechanically mix the KBS MAXX Clear Base until smooth, measure 3 parts Base to 1 part MAXX Activator, and mix thoroughly again. KBS MAXX Clear uses the same MAXX Activator as KBS MAXX.
3 parts KBS MAXX Base to 1 part MAXX Activator. KBS MAXX Clear uses the same 3 to 1 ratio.
Mixed KBS MAXX doubles in viscosity in 30 minutes, so mix only what you can apply in that time. Do not return mixed material to the original can.
It is pre-thinned and ready to brush, roll, or spray as mixed. If your equipment needs it, add KBS #1 Thinner or xylene, 5 to 10 percent for spraying, then mix again. Never use lacquer thinner as a reducer.
A mechanical mixer is highly recommended instead. KBS MAXX is a high solids coating, and a stir stick may not bring all of the components back together, which costs you appearance and durability.
Still have questions about KBS MAXX? Contact us for help.
