Yes -- galvanized touch-up is one of the primary applications for this product. When hot-dipped galvanized fencing, conduit, gutters, or structural steel gets scratched, welded, or cut, the zinc layer is damaged and bare steel is exposed. KBS Top Coater Galvanized Aerosol lets you quickly restore the protective coating and galvanized appearance with a spray can -- no spray equipment needed. Clean the area thoroughly to remove all rust and contaminants, then apply 1 to 2 thin coats. The flat galvanized finish blends closely with factory hot-dipped galvanized surfaces.
