Lower pressure gives a coarser texture, and higher pressure gives a finer one. Once the KBS Schutz Underseal Spray Gun is in a working pressure range for KBS UnderCoat, turn the pressure down for more texture and up for less.
Schutz Gun Pressure and UnderCoat Texture: Quick Facts
Gun working range: 45 to 150 PSI
More texture: lower the pressure
Less texture: raise the pressure
Thinning: not usually needed
Sprays through: the standard nozzle, not the 48 inch wand
Feeds from: a standard US dome style quart can
Not through the wand: the 48 inch probe is sized for thin cavity wax. Forcing KBS UnderCoat through it clogs the 360 degree tip. Spray UnderCoat through the standard nozzle.
Dialing In the Texture
Start in a working range for the undercoating, then adjust. Dropping the pressure builds a coarser, heavier texture; raising it atomizes the coating finer for a smoother look. The adjusting screw at the nozzle opens or closes the spray pattern, so pattern and pressure together set the finish. Test on a scrap panel before you spray the vehicle.
KBS UnderCoat sprays unthinned in most cases. If you do thin it, use KBS #1 Thinner for the solvent based formulas or water for the water based formula.
Prep and Spray Conditions
Clean the surface with KBS Klean diluted 5 to 1 and let it dry. Mask the auto finish, exhaust, brakes and moving parts. For best results, spray between 70 and 90 degrees F at 50% humidity or less, in light coats. The KBS UnderCoat directions cover dry times and cleanup.
Frequently Asked Questions: Schutz Gun Pressure and KBS UnderCoat
Once the gun is in a working pressure range for the undercoating, lower pressure creates more texture and higher pressure creates less.
It depends on the gun and the coating. The KBS Schutz Underseal Spray Gun works from 45 to 150 PSI; for KBS UnderCoat, use the pressure to set the texture.
Usually not. If you do, thin the solvent based formulas with KBS #1 Thinner and the water based formula with water.
No. The wand is for thin cavity wax such as Cavity Coater. KBS UnderCoat goes through the standard nozzle; forcing it through the wand clogs the tip.
It opens or closes the spray pattern at the nozzle, which works with the air pressure to set the texture.
Between 70 and 90 degrees F with 50% humidity or less, on a surface cleaned with KBS Klean and fully dry.
Still have questions about spraying undercoating? Contact us and we will help.
