Vehicles
Surfaces
Start here
Browse every guide →
Frame & chassis
Stop Rust systems
Try it first
Tank & clear coat
Find my kit →
Videos & How-To's
Product FAQs
Company
Resellers
Orders & shipping
"I tried this product myself ... WORKED GREAT!!!!!"
Dave Stewart, Product Specialist for JP Cycles
The KBS Large Cycle Tank Sealer PLUS Kit contains everything you need to strip and seal a tank of up to 12 gallons.
Gold Standard Fuel Tank Sealer, is a superior, single-component, ready-to-use fuel tank sealer.
This kit contains our KBS Klean (a water-based, heavy-duty, cleaner/degreaser) and RustBlast (a powerful rust remover/metal etch) to obtain a permanently sealed, rust-free fuel tank. These KBS prep products are formulated to leave a zinc phosphate film that promotes the adhesion of the Tank Sealer.
Our Customers Say It Best...
steel, aluminum & fiberglass fuel tanks • diesel tanks • oil tanks • utility tanks • non-potable water tanks
Learn how to seal up a Motorcycle Gas Tank with the KBS Cycle Tank Sealer Kit which gives you everything you need to seal a tank of up to 5 gallons.
Covers cleaning the tank with KBS Klean and etching the tank with RustBlast.
4.9
