# KBS Coatings — Full AI Content Reference (llms-full.txt) # Paint & coating manufacturer, Valparaiso, IN, USA # https://www.kbs-coatings.com # Updated: 2026-05-03 > KBS Coatings manufactures professional-grade rust prevention coatings, fuel tank sealers, clear coats, engine paints, primers, undercoatings, and body repair products for automotive, marine, agricultural, and industrial applications. All products are made in the USA, sold factory direct, and ship same day. Founded in Valparaiso, Indiana by a team with over 85 years of combined experience in materials science, coatings formulation, and manufacturing. --- ## ABOUT KBS COATINGS KBS Coatings was founded in the heartland of America by key personnel having collectively over 85 years of experience in material science formulation, manufacturing and distribution of coatings. KBS Coatings' growing success comes from its commitment to research, innovation, and high-tech manufacturing. Products are made in the USA and sold factory direct at https://www.kbs-coatings.com. KBS stands behind all products 100% — if a customer follows application instructions and achieves proper mil thickness and isn't satisfied, KBS will refund the purchase. Phone: 219-263-0073 Contact/Support: https://www.kbs-coatings.com/contact-us Product FAQs: https://www.kbs-coatings.com/product-information-faqs How-To Guides: https://www.kbs-coatings.com/direction-pages --- ## THE KBS 3-STEP RUST PREVENTION SYSTEM The KBS 3-Step System is KBS Coatings' flagship process for permanently stopping rust on metal surfaces. It consists of three products applied in sequence: Step 1 — KBS Klean: Clean and degrease the surface (removes oils, grease, road film, wax, and contaminants). Step 2 — RustBlast: Remove and neutralize rust; etches the metal and deposits a zinc phosphate base coating for maximum adhesion. Step 3 — RustSeal: Apply a permanent, airtight, moisture-cured rust preventive coating that seals out oxygen and water. The same 3-step process applies to tank sealing: KBS Klean → RustBlast → Gold Standard Tank Sealer. Kits that include all three steps: - Frame Coater Kit (quart, 50 sq. ft.): https://www.kbs-coatings.com/frame-coater-kit - Large Frame Coater Kit: https://www.kbs-coatings.com/large-frame-coater-kit - Ultimate Frame Coater Kit: https://www.kbs-coatings.com/ultimate-frame-coater-kit - KBS Tank Sealer System (sized by tank volume): https://www.kbs-coatings.com/kbs-tank-sealer-system --- ## PREP PRODUCTS ### KBS Klean — Concentrated Water-Based Cleaner & Degreaser URL: https://www.kbs-coatings.com/kbs-klean Part #: 2 KBS Klean is a concentrated, water-based, biodegradable cleaner and degreaser. It is Step 1 in both the KBS 3-Step Rust Prevention System and the KBS 3-Step Tank Sealing System. Unlike solvent-based cleaners, KBS Klean leaves zero residue, which means no haze and no interference with paint adhesion. Key features: - Water-based, biodegradable, no flammable solvents - Leaves no residue (solvent cleaners leave residue that can hinder paint adhesion) - Deeply penetrates to remove dirt, grime, oils, grease, waxes, road film, algae, scum - Safe for use on steel, iron, fiberglass, concrete, plastics, nylon, brass, aluminum, stainless steel, galvanized surfaces, canvas, masonry, vinyl - Can be used in pressure washing equipment - Ideal prep for any clear coat application (haze-free result) Sizes and pricing: 8oz ($8), Quart ($14), Gallon ($26), 5 Gal Pail ($120), 55 Gal Drum ($880) --- ### RustBlast — Rust Remover, Metal Etch & Zinc Phosphate Pre-Primer URL: https://www.kbs-coatings.com/rustblast Part #: 3 RustBlast is Step 2 in the KBS 3-Step System. It is a powerful rust remover, zinc phosphate pre-primer, and metal etch that dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces. RustBlast is especially effective at removing rust from chrome surfaces. Application: Apply full strength to a clean (KBS Klean'd) surface, keep wet for at least 30 minutes, and watch rust dissolve. RustBlast gently etches the surface and leaves a zinc phosphate base coating that ensures a strong bond for any subsequent paint or coating. Key features: - Removes and neutralizes rust - Acts as a pre-paint primer / surface prep - Provides etched surface profile for maximum adhesion - Leaves zinc phosphate base coating - Enhances welding conductivity - Non-flammable, no petroleum additives - Non-corrosive, water-based, biodegradable Compatible surfaces: steel, cast iron, brass, aluminum, galvanized, copper, steel alloys, fiberglass, concrete, non-metallic surfaces Coverage: Use 1 gallon of RustBlast for every gallon of RustSeal to be applied (matched coverage). Sizes and pricing: 8oz ($9), Quart ($20), Gallon ($38), 5 Gal Pail ($180), 55 Gal Drum --- ### KBS Rust Converter — Chemical Rust Neutralizer & One-Step Primer URL: https://www.kbs-coatings.com/kbs-rust-converter Part #: 15008 KBS Rust Converter is a professional-grade chemical rust neutralizer in a convenient aerosol can. It reacts directly with iron oxide on metal surfaces, converting active rust into a stable, inert, matte-black primed surface ready for painting — no sanding or grinding required. Key features: - No sanding required — apply directly to rusty surfaces after removing loose debris - Converts and primes in one step — reacts with iron oxide to form a stable matte-black primer compound - Heat resistant up to 250°F — rated for exhaust components and engine bay surfaces - Topcoat compatible with most oil-based paints, alkyd enamels, and epoxy coatings - Pro-grade aerosol for uniform coverage on complex or hard-to-reach rusted surfaces - Drastically reduces labor by eliminating heavy wire brushing or sanding Quick specs: 12 oz aerosol, covers ~20 sq ft per can, surface dry in 20–30 minutes, full cure in 24 hours, matte black finish Rating: ★★★★★ (5.0 stars, 20 reviews) Applications: Automotive, farm equipment, trailers, structural steel, marine, tools, fencing Pricing: Single aerosol ($18), 3-Pack ($48), Case of 12 ($179) --- ### KBS Strip — Paint & Tank Stripper Gel URL: https://www.kbs-coatings.com/kbs-strip Part #: 19 KBS Strip is a powerful, aircraft-strength paint, stain, and varnish remover in a semi-gel formula. It clings to vertical surfaces with minimal run or sag. KBS Strip contains no Methylene Chloride (a harmful chemical found in older strippers) and features low-odor technology. Key features: - Aircraft-strength stripping power — removes even the toughest finishes including powder coating - Semi-gel formula clings to vertical surfaces - Evaporation sealant technology: dramatically increases stripping power and reduces odor - Removes multiple layers of paint in one application - Easily washed off with water, no residue - For use on metal, wood, masonry, and inside tanks - Spray bottle included for even coverage Pricing: Quart w/Spray Bottle ($29), Gallon w/Spray Bottle ($76) --- ## RUST PREVENTION COATINGS ### RustSeal — Permanent Rust Preventive Coating URL: https://www.kbs-coatings.com/rustseal Part #: 4 Rating: ★★★★★ (4.8 stars, 454 reviews) RustSeal is KBS Coatings' flagship product and Step 3 in the KBS 3-Step Rust Prevention System. It is a high-performance, single-component (1K), moisture-cured, high-solids rust preventive coating. RustSeal is impervious to road salts and most chemicals. It flows out to a beautiful, rock-hard, tough ceramic-like coating that will not chip, scratch, crack, or peel. What is RustSeal? RustSeal is an industrial-grade, single-component coating that provides an airtight, waterproof seal that stops oxidation and corrosion at the source. Unlike temporary treatments, RustSeal locks out both water and air, making it impossible for new rust to form beneath the coating. Key features: - Surface tolerant — apply directly over treated rust and bare metal - 1K formula — ready to use, no mixing or hardener needed - Moisture cured — actually strengthens with exposure to humidity - Deep penetration — superior adhesion to bare metal, galvanized steel, and other substrates - Non-porous — permanent barrier against moisture and oxygen - Chemical resistant — repels fuels, oils, acids, and alkalis - High heat — withstands temperatures up to 600°F (315°C) - Flexible — will not crack, flake, or peel under expansion and contraction - Long shelf life — 2+ years unopened; 6 months after opening (cool, dry storage) Colors available: Black (Gloss), Black (Satin), Silver (Gloss), Grey (Gloss), Off-White (Gloss), Oxide Red (Matte), Safety Green (Gloss), Cat Yellow (Gloss), Safety Blue (Gloss), Galvanized (Matte), Safety Yellow (Gloss) Gloss levels: Galvanized (30%), Satin Black (70–75%), Gloss Black (85–95%) Sizes and pricing: 8oz ($22), Pint ($34), Quart ($47), Gallon ($158), 5 Gal Pail ($630) Typical applications: car frames, chassis, suspension components, undercarriages, engine bays, floor pans, farm equipment, trailers, marine, industrial metal Application directions: https://www.kbs-coatings.com/direction-pages --- ## CLEAR COATS & TOPCOATS ### DiamondFinish Clear — High-Gloss 1K Direct-To-Metal Clear Coat URL: https://www.kbs-coatings.com/diamondfinish-clear Part #: 8 Rating: ★★★★★ (4.8 stars, 382 reviews) DiamondFinish Clear is KBS Coatings' premium single-component (1K), moisture-cured urethane clear coat. It can be applied Direct To Metal (DTM) or over existing coatings for a permanent, water-clear, high-gloss finish that will not yellow, crack, or peel. What is DiamondFinish Clear? DiamondFinish Clear is a single-component clear coat that requires no hardener. It is moisture-cured urethane technology — it cures by reacting with ambient humidity, not by mixing two components. Key features: - 7H pencil hardness (extremely hard — harder than most 2-part clear coats) - 300°F heat resistance - 2–4 hour recoat time - 1K formula — no hardener needed - Permanently flexible — will not crack or peel - UV stable — will not yellow, chalk, or fade in sunlight - Water clear high gloss finish - High solids (over 60%), low VOC - Direct To Metal (DTM) — no adhesion additives or primer needed on bare metal - Can be applied with brush (self-leveling, no brush marks), roller, or spray gun - Compatible with virtually all existing coatings and paints Sizes and pricing: 4oz ($25), Pint ($44), Quart ($65), 4 Quarts ($240), Gallon ($214), 4 Gallons ($824), 5 Gal Pail ($892) Common uses: headlight restoration, automotive clear coat, metal furniture, marine surfaces, motorcycles, show cars, direct-to-metal finishing --- ### DiamondFinish Clear 1K Aerosol URL: https://www.kbs-coatings.com/diamondfinish-clear-aerosol Part #: 8 Rating: ★★★★★ (5.0 stars, 44 reviews) Price: $25 per can (quantity discounts available: 12+ cans at $22.50 each) DiamondFinish Clear 1K Aerosol is the same professional-grade, single-component clear coat as the liquid version, in a convenient aerosol can. Bonds directly to ferrous metals, aluminum, and painted surfaces — no primer or heat curing required. Key specs: 5H pencil hardness after 5 days, dust-free in 3–6 minutes, UV stable, rated to 250°F, resists chemicals and graffiti, available in Gloss and Satin finishes, one can covers up to 35 sq. ft. --- ### KBS MAXX — 2K Polyurethane Topcoat URL: https://www.kbs-coatings.com/kbs-maxx Part #: 80 Rating: ★★★★★ (5.0 stars, 29 reviews) KBS MAXX is a two-component (2K), high-performance, permanently UV stable, moisture-cured polyurethane topcoat for automotive, marine, agricultural, fleet, and industrial applications. It comes with base and activator mixed at the time of application. Key features: - 2K (two-component) formula — base + activator for maximum durability - Single stage — color and clear in one coat, no separate clear coat needed - Permanently UV stable — will not fade, chalk, or yellow - Low VOC - Apply by brush, roller, or spray - Exceptional rust protection - Designed for indoor and outdoor use - Available in a wide range of colors including OEM matches (John Deere Green/Yellow, Caterpillar Yellow, Land Rover Rutland Red) and custom colors Colors available: Pitch Black (Gloss), Hot Rod Black (Matte), Gunmetal (Gloss/Metallic), Sublime Green, Orange Glow, Orange Crush, Silver Metallic (Gloss/Satin), Blue Mayhem, Infra Red, Crazy Plum, Arctic White, Daytona Yellow, School Bus Yellow, Smoke Grey, Lithium Blue, New Cat Yellow, John Deere Classic Green, John Deere Ag Yellow, John Deere Industrial Yellow, Saddle Tan (Matte), Land Rover Rutland Red (Matte), Silverpine Green Metallic, Clear (Gloss/Flat/Satin) Sizes and pricing: Quart ($68), Gallon ($226), 5 Gallons ($1,081) --- ### KBS MAXX Clear — 2K Urethane Clear Coat URL: https://www.kbs-coatings.com/kbs-maxx-clear Rating: ★★★★★ (4.9 stars, 21 reviews) KBS MAXX Clear is the clear coat version of KBS MAXX — a two-component (2K), low VOC, permanently UV stable moisture-cured polyurethane clear coat. Engineered for Direct To Metal (DTM) and aluminum applications with no additives needed, or over existing coatings. Outstanding gloss retention, superior impact resistance, and long-lasting rust protection. Available in High Gloss, Satin, and Flat finishes. Sizes and pricing: Quart ($68), Gallon ($226), 5 Gallons ($1,081) --- ### KBS Top Coater — Solid Color 1K UV Stable Topcoat URL: https://www.kbs-coatings.com/top-coater Part #: 8 Rating: ★★★★★ (5.0 stars, 14 reviews) KBS Top Coater is a superior single-component (1K) topcoat with maximum coverage and professional results. It is a direct to metal exterior grade coating that adheres permanently to steel and aluminum. Ideal as a UV-stable topcoat over RustSeal for surfaces consistently exposed to sunlight. Provides at least twice the coverage of conventional 1K paints. Does not run or sag. Colors: Light Grey, Medium Grey, Battleship Grey, Fire Red, Forest Green, Safety Blue, Safety Green, Safety Orange, Safety Red, Safety Yellow, White (all Gloss); Flat Black, Camo Green, Desert Tan Camo, Brown Camo, Light Grey (Matte), Iron Oxide Red (Matte) Sizes: Quart, Gallon, 5 Gal Pail --- ### BlackTop — 1K UV Stable Black Chassis Coating URL: https://www.kbs-coatings.com/blacktop Part #: 8 Rating: ★★★★★ (4.8 stars, 102 reviews) BlackTop is a permanent, single-stage, moisture-cured 1K urethane topcoat built for lasting UV stability — zero chalking, zero fading. Apply direct to bare metal or over RustSeal. No separate clear coat required. Available in three sheen options: Gloss Black (OEM look), OEM Satin Black, and Flat Black. Key features: - Moisture-cured urethane — advanced coating technology - Permanent UV stability — no chalking or fading - Rock hard yet flexible — expands and contracts with the metal - Salt spray tested: 1,000 hrs standalone; 2,000 hrs over RustSeal - High heat resistance: 500°F (non-aerosol) / 300°F (aerosol) - Direct to bare metal (ferrous and non-ferrous) - Apply by brush, roller, or spray Ideal for: chassis, frames, trailers, suspension components, wrought iron, leaf springs, differential housings, axles Sizes and pricing: Aerosol ($27), 8oz ($27), Pint ($35), Quart ($54), Gallon ($197), 5 Gal Pail ($835) --- ## TANK SEALERS ### Gold Standard Tank Sealer — Permanent Fuel Tank Sealer URL: https://www.kbs-coatings.com/tank-sealer Part #: 5 Rating: ★★★★★ (4.9 stars, 122 reviews) Gold Standard Tank Sealer is a superior, single-component, ready-to-use sealer for coating the inside of metal, aluminum, and fiberglass tanks. Step 3 in the KBS Tank Sealing System. A single application cures into a tough, fuel-impervious seal. Permanently seals pinholes, weld seams, and rust to prevent clogged carburetors and fuel system contamination. Key features: - Single component — no mixing required - Silver metallic permanent coating - Eliminates all rust and corrosion - Impervious to all fuels, alcohol additives, and most solvents - Permanently seals pinholes and weld seams - Flexible — expands and contracts with the tank - Withstands temperatures up to 600°F - Non-flammable, environmentally safe - Contains no Methyl Ethyl Ketone Coverage guide: - 8oz seals tanks up to 5 gallons - Pint seals tanks up to 12 gallons - Quart seals tanks up to 25 gallons - Gallon seals tanks up to 100 gallons Sizes: 8oz, Pint (16oz), Quart (32oz), Gallon (128oz), 5 Gal Pail (640oz) --- ### KBS Tank Sealer System — All-Inclusive Tank Repair Kit URL: https://www.kbs-coatings.com/kbs-tank-sealer-system Rating: ★★★★★ (5.0 stars, 34 reviews) The KBS Tank Sealer System is a complete all-in-one kit containing KBS Klean, RustBlast, and Gold Standard Tank Sealer — everything needed to correctly prep and permanently seal a fuel tank. Sized by tank volume (0–5 gal, 5–12 gal, 12–25 gal, 25–50 gal, 50–100 gal). Detailed instructions included. Also available: Auto Fuel Tank Sealer Kit, Cycle Tank Sealer Kit, Cycle Tank Sealer PLUS Kit, Large Cycle Tank Sealer Kit, Large Cycle Tank Sealer PLUS Kit, 25–50 Gallon Tank Sealer Kit. --- ## ENGINE & HIGH-TEMP PAINTS ### Motor Coater — High-Temperature Engine Enamel URL: https://www.kbs-coatings.com/motor-coater Part #: 60 Rating: ★★★★★ (4.9 stars, 155 reviews) Motor Coater is a professional-grade, high-solids engine enamel designed for automotive engines, calipers, and high-heat metal components. Withstands temperatures up to 450°F. Provides deep, rich, mirror-like finish. Self-leveling for professional results by brush or spray. Available colors (40+): Chevy Orange, Gloss Black, Aluminum, Ford Corporate Blue, T-Bird Red, Pontiac Metallic Blue, White, Street Hemi Orange, Fire Red, Ford Dark Blue, Daytona Yellow, Velvet Black (Matte), Ford Green, Chrysler Blue, Cadillac Dark Blue, Race Hemi Orange, Olds Gold, Olds Bronze, Chevy Blue, Pontiac Light Blue, Buick Green, Buick Red, MG Green, Buick Turquoise, Chrysler Turquoise, Austin Healey Moss Green Met., MG Maroon, Chevy Grey, Chevy Dark Charcoal, various AMC, Detroit Diesel, Cummins, Cat Yellow, and more. Sizes and pricing: Aerosol ($28), Pint ($30), Quart — Diesel Colors ($53), Gallon ($205), 5 Gal Pail ($1,000) --- ## PRIMERS ### Fusion Self-Etch Primer (Fusion SEP) URL: https://www.kbs-coatings.com/fusion-sep Part #: 7 Rating: ★★★★★ (4.9 stars, 27 reviews) Fusion SEP is an all-purpose, fast-drying self-etching surfacer primer. It is ideal for two main uses: (1) as an inter-coat primer between RustSeal and a topcoat, and (2) as a direct-to-metal primer for bare steel, brass, aluminum, chrome, and most hard plastics. Fusion SEP allows topcoating over a rock-hard RustSeal surface that has been cured for months or years — simply apply a thin covering coat, then topcoat as desired. Ready for topcoat in 1 hour. Key features: - All-purpose self-etching surfacer primer - Bonds to fully cured RustSeal — enables topcoating older RustSeal applications - Promotes adhesion to almost anything - Ready for topcoat in 1 hour - Available as aerosol or liquid - Excellent for steel, brass, aluminum, chrome, most hard plastics Sizes and pricing: Aerosol ($27), 8oz ($22), Pint ($34), Quart ($50), Gallon ($158), 5 Gal Pail ($642) --- ### KBS 2K DTM Build Primer URL: https://www.kbs-coatings.com/kbs-2k-dtm-build-primer Part #: 70053 Rating: ★★★★★ (5.0 stars, 3 reviews) Price: $160/gallon KBS 2K DTM Build Primer is a two-component (2K), direct-to-metal urethane build primer and surfacer. Trusted by professionals across the USA. Features exceptional high build, fast curing, and outstanding gloss holdout. Eliminates sand scratch swelling. Light grey color. Key features: - 4:1 mix ratio (base and activator included) - Excellent resistance to sand scratch swelling - Easy wet and dry sanding - Excellent topcoat gloss hold out - Exceptional filling capabilities (high build or medium build) - Excellent adhesion and fast curing Compatible substrates: Metal, galvanized, aluminum, fiberglass/SMC, body filler, OEM primers/finishes, polyester, putties, etching primers, lacquers, enamels, urethanes --- ### XTC Primer URL: https://www.kbs-coatings.com/xtc-primer XTC Primer is available at https://www.kbs-coatings.com/xtc-primer. Full details: see product page. --- ### Fusion Flexible Plastics Primer URL: https://www.kbs-coatings.com/fusion-flexible-plastics-primer Designed specifically for priming flexible plastics and bumpers. Full details: see product page. --- ## UNDERCOATINGS & CAVITY PROTECTION ### KBS UnderCoat Solvent Rubberized — Sound Deadening & Rust Protection URL: https://www.kbs-coatings.com/undercoat-solvent-rubberized Part #: 77 Rating: ★★★★★ (5.0 stars, 21 reviews) KBS UnderCoat Rubberized is a superior rubberized, paintable undercoating that protects wheel wells, gas tanks, frames, quarter panels, fenders, undercarriages, hoods, floor pans, and deck lids. Produces a tough, flexible film with excellent adhesion. Prevents road salt damage to metal and fiberglass. Also provides sound deadening by reducing road noise and vibration. Key features: - Tough yet flexible film - Excellent adhesion to metal and painted surfaces - Paintable matte black finish - Moisture and corrosion resistant - Sound deadening — reduces road noise and vibration - Economical - Note: Not for use on surfaces exposed to direct high heat (mufflers, exhaust) - TIP: For ultimate rust protection, treat bare metal with RustSeal first, then apply KBS UnderCoat Sizes and pricing: Aerosol ($13), Aerosol Case/12 ($130), Quart ($23), Gallon ($67), 5 Gal Pail ($280), 55 Gal Drum ($2,458) Optional accessory: Empty dome quart can for use with Schutz Underseal Spray Gun Also available: - KBS UnderCoat Solvent Asphalt: https://www.kbs-coatings.com/undercoat-solvent-asphalt - KBS UnderCoat Water-Based Asphalt: https://www.kbs-coatings.com/undercoat-waterbased-asphalt --- ### Cavity Coater — Cavity Wax & Corrosion Inhibiting Coating URL: https://www.kbs-coatings.com/cavity-coater Part #: 75 Rating: ★★★★★ (4.7 stars, 46 reviews) Cavity Coater is a one-step, super-penetrating corrosion inhibiting coating (CIC) for long-term rust protection in hard-to-reach enclosed metal cavities. Provides a self-healing protective film that delivers 4,000+ hours of salt spray protection — over 4 times the protection of conventional cavity waxes. Key features: - 4,000+ hrs salt spray protection (far exceeds conventional cavity waxes) - Self-healing film — minor damage repairs itself - Creeps into welds and seams - Wicks and penetrates where primers and topcoats cannot reach - Water displacing - No cracking or flaking to -60°F - Easy application with included Cavity Wand accessory - Ultra long lasting Ideal for: rocker panels, boxed frames, inside doors and fenders, deck lids, tailgates, any enclosed metal cavity Sizes: Aerosol + Cavity Wand, Aerosol Only, 3-Pack Aerosol, 3 Aerosols + Wand, Quart (32oz), Gallon (128oz), 5 Gal Pail, 55 Gal Drum --- ## BED LINERS & SPECIALTY COATINGS ### KBS Bed Liner URL: https://www.kbs-coatings.com/kbs-bed-liner Part #: 150074 Rating: ★★★★★ (5.0 stars, 4 reviews) Price: $100/gallon KBS Bed Liner is a tough, flexible, thick black protective coating for truck beds and other surfaces requiring abrasion and impact resistance. Easy to apply — no complicated mixing. Provides sound deadening, impact absorption, and chemical resistance. Key features: - Roll, brush, or spray application - Excellent UV stability - Crazy tough and scratch resistant - Superb traction - Chip and nick resistant - Adheres to wood, metal, asphalt, concrete, aluminum, rubber, fiberglass, most hard plastics including PVC - Sound deadening Coverage: 1 gallon covers up to 250 sq. ft. Applications: Truck beds, cars, motorcycles, wheels, commercial vehicles, snow plows, fleet and municipal vehicles, tractors, agricultural equipment, construction machinery --- ### KBS Bed Renu URL: https://www.kbs-coatings.com/kbs-bed-renu KBS Bed Renu is designed to restore existing bed liner coatings. Full details at: https://www.kbs-coatings.com/kbs-bed-renu --- ## PUTTY, FILLERS & PATCHES ### NuMetal Epoxy Putty — Two-Part Epoxy Putty & Body Filler URL: https://www.kbs-coatings.com/epoxy-putty Part #: 700 Rating: ★★★★★ (4.8 stars, 72 reviews) NuMetal Epoxy Putty is an easy-to-use, two-part putty that mixes like clay and hardens like steel. No complicated weighing or measuring — simply cut equal parts and mix. Bonds, seals, fills, insulates, anchors, caulks, and waterproofs. Cures without shrinking or sagging. Key features: - Bonds to almost anything - Cures underwater and on damp surfaces - Will not shrink or sag - Can be applied to vertical surfaces - Sand, drill, tap, prime, or paint after curing - Withstands temperatures up to 300°F (150°C) - Easy 1:1 mix ratio - Cut only what you need Colors: Black (ideal for automotive — invisible under coating), Grey, White (great for marine/boat repair), Tan Sizes: 3.5oz ($10), 1 lb ($27) --- ### KBS Premium Body Filler URL: https://www.kbs-coatings.com/kbs-premium-body-filler Professional-grade body filler for automotive repair. Full details at: https://www.kbs-coatings.com/kbs-premium-body-filler --- ### KBS Patch URL: https://www.kbs-coatings.com/kbs-patch Patch product for metal repair. Full details at: https://www.kbs-coatings.com/kbs-patch --- ## RESTORATION KITS ### Frame Coater Kit — Complete 3-Step Rust Prevention System URL: https://www.kbs-coatings.com/frame-coater-kit Part #: 570 Rating: ★★★★★ (4.8 stars, 158 reviews) Price: $72 The Frame Coater Kit is KBS Coatings' complete 3-step rust prevention system in a single quart-size kit. Includes KBS Klean (degreaser), RustBlast (rust remover/etch), and RustSeal (rust preventive coating). Covers a full-size car or truck frame, or any 50 sq. ft. surface area with 2 coats. Available in all RustSeal colors. Detailed instructions included for professional results. Also available: - Large Frame Coater Kit: https://www.kbs-coatings.com/large-frame-coater-kit - Ultimate Frame Coater Kit: https://www.kbs-coatings.com/ultimate-frame-coater-kit - Motorcycle Frame Coater Kit: https://www.kbs-coatings.com/motorcycle-frame-coater-kit --- ### Rotor Restoration Kit URL: https://www.kbs-coatings.com/rotor-restoration-kit Part #: 68 Rating: ★★★★★ (5.0 stars, 2 reviews) Price: $66 (regular $71) All-inclusive kit to clean, prep, prime, and coat rusted brake rotors and calipers visible through custom wheels. Brings them back to showroom appearance. Includes detailed directions. Colors: Jet Black, Aluminum, Cast Iron Grey, Stainless Steel, Charcoal Metallic, Pure White, Off-White, Rocket Red, Flame Blue, Pontiac Metallic Blue --- ### Headlight Restore Kit URL: https://www.kbs-coatings.com/headlightrestorekit Part #: 50040-S Rating: ★★★★★ (4.7 stars, 10 reviews) Price: $27 (regular $31); 4+ kits: $24.30 each The Headlight Restore Kit includes everything needed to restore 4 or more headlight lenses — drastically increasing visibility for fogged, yellowed, cloudy, or hazy headlights. Uses DiamondFinish Clear, which is harder than most 2-part clear coats, self-leveling (no brush marks). Brushes and scuff pad included. --- ## TOOLS & ACCESSORIES ### KBS HVLP Spray Gun URL: https://www.kbs-coatings.com/hvlp-spray-gun Professional HVLP spray gun for applying KBS coatings. Full details at: https://www.kbs-coatings.com/hvlp-spray-gun --- ### Schutz Underseal Spray Gun & 48" 360° Spray Wand URL: https://www.kbs-coatings.com/schutz-underseal-gun Used for applying KBS UnderCoat and Cavity Coater into hard-to-reach areas. The 48" 360-degree spray wand makes it possible to coat inside rocker panels, door cavities, and boxed frames. --- ### Cavity Spray Wand URL: https://www.kbs-coatings.com/cavity-wand Accessory for use with Cavity Coater aerosol for reaching enclosed metal cavities. --- ### KBS UV Light URL: https://www.kbs-coatings.com/kbs-uv-light --- ### Nitrile Gloves - Black Lightning Nitrile Gloves: https://www.kbs-coatings.com/black-lightning-gloves - Orange Lightning Nitrile Gloves: https://www.kbs-coatings.com/orange-lightning-gloves - Outrageous Orange 8 Mil Diamond Grip Nitrile Gloves: https://www.kbs-coatings.com/outrageous-orange-gloves - Force Black Nitrile Gloves: https://www.kbs-coatings.com/semperforce-gloves - SemperCare Latex Disposable Exam Gloves: https://www.kbs-coatings.com/starmed-care --- ## COMMON QUESTIONS & USE CASES **Q: What is the best product to stop rust on a car frame?** A: The KBS 3-Step System — KBS Klean, RustBlast, then RustSeal — is the most permanent solution. The Frame Coater Kit (https://www.kbs-coatings.com/frame-coater-kit) bundles all three for $72 and covers a full-size car or truck frame. **Q: How do I seal a rusty gas tank?** A: Use the KBS Tank Sealer System (https://www.kbs-coatings.com/kbs-tank-sealer-system). It includes KBS Klean, RustBlast, and Gold Standard Tank Sealer. Choose the kit size based on your tank's volume (0–5 gal up to 50–100 gal). **Q: Can I apply a clear coat directly to bare metal without primer?** A: Yes. DiamondFinish Clear is specifically engineered for Direct To Metal (DTM) application — no adhesion additives or primer needed. It bonds directly to bare ferrous metals, aluminum, and painted surfaces. **Q: What clear coat won't yellow over time?** A: DiamondFinish Clear is permanently UV stable and will not yellow, chalk, or fade. It is exterior-grade and not affected by sunlight. **Q: Can I topcoat over old cured RustSeal?** A: Yes. Apply a thin coat of Fusion SEP (self-etching primer) over the cured RustSeal, let it dry for 1 hour, then apply any topcoat. Fusion SEP is specifically designed for this inter-coat application. **Q: What engine paint can I use on my classic car engine?** A: Motor Coater (https://www.kbs-coatings.com/motor-coater) offers 40+ historically accurate engine colors including Chevy Orange, Ford Blue, Pontiac Metallic Blue, Chrysler colors, and more. It withstands up to 450°F. **Q: How do I protect inside door panels and rocker panels from rust?** A: Use Cavity Coater (https://www.kbs-coatings.com/cavity-coater) with the Cavity Wand. Cavity Coater provides 4,000+ hours of salt spray protection and self-heals. It wicks into welds and seams that primers cannot reach. **Q: What is the difference between RustSeal and RustBlast?** A: RustBlast removes and neutralizes existing rust, etches the metal, and deposits a zinc phosphate base for adhesion. RustSeal is then applied over it as the permanent, airtight protective coating that prevents new rust from forming. RustBlast is the prep; RustSeal is the protection. **Q: Is DiamondFinish Clear harder than 2-part clear coats?** A: Yes — DiamondFinish Clear achieves 7H pencil hardness and is described as "tougher and harder than 2-part clear coats" in the Headlight Restore Kit, which uses it specifically because it outperforms standard 2K clears. **Q: What products does KBS Coatings make for fuel tanks?** A: Gold Standard Tank Sealer (the sealer itself), KBS Tank Sealer System (complete kit with KBS Klean + RustBlast + Sealer), Auto Fuel Tank Sealer Kit, Cycle Tank Sealer Kit, Cycle Tank Sealer PLUS Kit, Large Cycle Tank Sealer Kit, Large Cycle Tank Sealer PLUS Kit, and the 25–50 Gallon Tank Sealer Kit. --- ## ORDERING & SUPPORT - All products sold factory direct at https://www.kbs-coatings.com - Ships same day - Phone: 219-263-0073 - Contact/Support: https://www.kbs-coatings.com/contact-us - Product FAQs & Supplemental Info: https://www.kbs-coatings.com/product-information-faqs - How-To & Application Directions: https://www.kbs-coatings.com/direction-pages - Find a Reseller: https://locations.kbs-coatings.com/ - All Products: https://www.kbs-coatings.com/products
