Motor Coater Engine Paint is designed to brush on smoothly, but it can also be converted into a professional-quality engine paint aerosol for easy spray application. Many Motor Coater colors are available pre-packaged in aerosol cans, and every color can be spray-applied using a simple thinning method with a Preval Sprayer Kit.
To create your own engine paint aerosol, reduce Motor Coater 30 to 40 percent with KBS #1 Thinner or xylene, then spray through a Preval Sprayer Kit. The result is the same smooth, durable, heat-resistant finish as a factory aerosol, in any Motor Coater color you choose.
This method is ideal for custom colors, small touch-ups, or when your preferred shade is not available in a ready-to-use spray can.
Quick method: Reduce Motor Coater 30 to 40 percent with KBS #1 Thinner or xylene, load into a Preval Sprayer, then spray like any aerosol can.
What You Need
FinishGloss / Flat (Velvet Black)
Heat ResistanceUp to 500°F
ApplicationBrush, roller, or spray
Colors42 factory-matched colors
Shop Motor Coater
Preval Sprayer Kit
TypePortable aerosol spray system
Compatible WithMotor Coater (thinned)
Best ForTouch-ups, custom colors
ReusableYes, refillable glass jar
Shop Preval Sprayer
UseReduce Motor Coater for spray
Mix Ratio30-40% reducer by volume
Also AcceptsXylene as alternative
Cleans UpSprayer jar and equipment
Shop KBS #1 Thinner
For full surface prep, coat counts, and cure times, see the complete Motor Coater Application Directions.
Frequently Asked Questions: Motor Coater as Aerosol
Yes. Any Motor Coater color can be converted to an aerosol spray using a Preval Sprayer Kit. Reduce the paint 30 to 40 percent with KBS #1 Thinner or xylene and spray normally. This gives you full access to the entire Motor Coater color range in spray form.
Motor Coater should be reduced 30 to 40 percent with KBS #1 Thinner or xylene for best atomization and flow when sprayed through a Preval Sprayer or conventional spray gun. Thinning too little can clog the sprayer; thinning too much can reduce film build and durability.
Yes. Sprayed Motor Coater provides the same heat resistance, chemical resistance, and long-term durability as brushed application when properly thinned and applied. Multiple thin coats are recommended over one heavy coat for the best finish.
Motor Coater can be applied directly to properly prepared metal. For maximum adhesion on bare steel, clean with KBS Klean and etch with RustBlast following the Motor Coater Application Directions before painting.
Still have questions about Motor Coater or spray application?
Contact KBS Coatings Support Shop Motor Coater
