Motor Coater does not need to be heat cured. It is formulated to cure completely through ambient air exposure at room temperature, with a standard air cure taking up to seven days for a full, durable finish.
Want to Speed Up the Cure?
Two options work for speeding up Motor Coater's cure: heat cycling in the sun, or force curing with a controlled heat source. Force curing is the faster of the two and is a good fit for time-sensitive jobs where the part can go into an oven or under a heat lamp.
You can heat cycle the piece by alternating 1 hour in the sun and 1 hour in the shade.
Force Curing Motor Coater
For time-sensitive jobs, Motor Coater can be force cured at 140°F to 180°F for 20 to 30 minutes. This step is optional; Motor Coater reaches full hardness with a standard 7-day air cure on its own. Force curing is simply a faster path to that same full cure for builders who cannot wait a week before handling or reinstalling the part.
For full surface prep, coat counts, and application steps, see the complete Motor Coater Application Directions.
Frequently Asked Questions: Motor Coater Curing
Still have questions about curing Motor Coater? Contact us for help.
