To prepare a marine engine for Motor Coater, clean the entire engine with KBS Klean, treat any rust spots with RustBlast, prime with RustSeal for maximum corrosion protection, then apply Motor Coater as the finish coat.
Marine Engine Prep: Quick Steps
1. Clean
KBS Klean, full engine
2. Treat rust
RustBlast on rust spots
3. Prime
RustSeal for corrosion protection
4. Coat
Motor Coater finish
Why This Order Matters
Marine engines are exposed to salt air, moisture, and engine bay heat, all of which accelerate corrosion on bare metal. Cleaning first with KBS Klean removes oil, salt residue, and grime so RustBlast can properly etch and treat any rust spots underneath. Priming with RustSeal after that adds a permanent, rust-proof barrier, which matters most in a salt air environment where corrosion pressure is constant. Applying Motor Coater over a cleaned, rust-treated, RustSeal-primed surface gives the finish a stable, corrosion-resistant base rather than coating over contamination that will undermine adhesion later.
For full surface prep steps, coat counts, and cure times, see the complete Motor Coater Application Directions.
Frequently Asked Questions: Motor Coater on Marine Engines
Clean the entire engine with KBS Klean to remove oil, salt residue, and grime. Treat any rust spots with RustBlast to etch bare metal and neutralize corrosion. Prime with RustSeal for maximum corrosion protection in a salt air environment. Once cleaned, treated, and primed, apply Motor Coater as the finish coat.
Motor Coater is used to coat marine engines when the surface is properly prepped first. Salt air and moisture accelerate corrosion, so cleaning with KBS Klean, treating rust spots with RustBlast, and priming with RustSeal before coating gives the finish a stable, corrosion-resistant base.
Yes. Coating over untreated rust traps corrosion under the finish and undermines adhesion. Treat any rust spots with RustBlast after cleaning and before applying Motor Coater.
Yes, it is recommended. RustSeal provides a permanent, rust-proof barrier that holds up well against the constant salt air and moisture exposure marine engines face. Priming with RustSeal after cleaning and rust treatment, and before applying Motor Coater, gives the finish the strongest possible protection against corrosion.
Still have questions about coating a marine engine? Contact us for help.
