Motor Coater is ideal for coating an oil pan. Clean the pan with KBS Klean, etch with RustBlast, prime with RustSeal, then finish with Motor Coater for the most durable, long-lasting result.
Oil Pan Prep: Quick Steps
1. Clean
2. Etch
3. Prime
4. Coat
Why prime an oil pan: Oil pans see heavy road debris and moisture exposure. Priming the prepped pan with RustSeal creates a permanent, rust-proof barrier before the Motor Coater color coat, and provides the longest-lasting finish for a part that lives close to the road.
For full surface prep, coat counts, and cure times, see the complete Motor Coater Application Directions.
Frequently Asked Questions: Motor Coater on Oil Pans
Yes, Motor Coater is ideal for oil pans. It provides a durable, heat-resistant finish that stands up to the harsh environment under your vehicle.
Use the KBS 3-Step System: clean with KBS Klean, etch with RustBlast, and for maximum rust protection, prime with RustSeal before applying the Motor Coater finish coat.
Priming is strongly recommended. Oil pans face heavy road debris and moisture exposure, so priming the prepped pan with RustSeal creates a permanent, rust-proof barrier before the Motor Coater color coat and extends the life of the finish.
Still have questions about coating an oil pan? Contact us for help.
