No special prep or etching is required to apply Motor Coater to aluminum. Clean the surface thoroughly with KBS Klean to remove oils and oxidation, then apply Motor Coater directly once the surface is dry.
Motor Coater on Aluminum: Quick Facts
Etching needed? No, clean only.
Prep: Clean with KBS Klean, dry, then apply.
Motor Coater is formulated to adhere exceptionally well to aluminum substrates without a specialized primer. The key step is thorough cleaning: aluminum surfaces often carry a thin oxide layer along with oils and grime from handling, and KBS Klean removes both before you coat.
For full surface prep, coat counts, and cure times, see the complete Motor Coater Application Directions.
Frequently Asked Questions: Motor Coater on Aluminum
No special etching or prep is required for aluminum. Simply clean the surface thoroughly with KBS Klean to ensure it is free of contaminants before applying Motor Coater.
Motor Coater is formulated to adhere exceptionally well to aluminum surfaces, providing a durable, long-lasting finish without the need for specialized primers.
No etching step is required for Motor Coater on aluminum. Thorough cleaning with KBS Klean to remove oils and oxidation is sufficient surface prep before applying the coating.
Still have questions about coating aluminum parts? Contact us for help.
