Yes, Motor Coater works well on spindles, upper A-arms, and other suspension and chassis parts. It is an exterior-grade, UV-stable coating that adheres to a variety of surfaces and holds its show-quality finish outdoors.
Motor Coater on Suspension Parts: Quick Facts
Coating type: Exterior-grade, UV-stable enamel
Recommended primer: RustSeal for rust-prone parts
For spindles, A-arms, and similar suspension components, most builders prime prepped surfaces with RustSeal first to create a permanent rust-proof foundation, then top coat with Motor Coater for the final color.
For extra durability: On parts prone to rock chips and road debris, some builders let Motor Coater cure fully (7 days) and then add a top coat of DiamondFinish Clear for added scratch and chemical resistance. DiamondFinish Clear is formulated to apply over cured single-part (1K) paints like Motor Coater; follow the DiamondFinish Clear directions for full application steps.
For full surface prep, coat counts, and cure times, see the complete Motor Coater Application Directions.
Frequently Asked Questions: Motor Coater on Suspension Parts
Yes. Motor Coater is an exterior-grade, UV-stable coating that adheres exceptionally well to spindles, A-arms, and other chassis components, providing a durable and beautiful finish.
For maximum rust protection on exterior suspension parts, prime prepped surfaces with RustSeal before applying the Motor Coater finish coat.
On parts prone to rock chips and road debris, some builders let Motor Coater cure fully for 7 days, then apply a top coat of DiamondFinish Clear for added scratch and chemical resistance. Confirm compatibility and application order in the DiamondFinish Clear directions before combining products.
Still have questions about coating suspension parts? Contact us for help.
