Yes, Motor Coater Engine Enamel is UV stable and designed for consistent sun exposure. As an exterior-grade coating, it holds its color depth and gloss over time even when applied to parts that see daily sunlight, such as engine bays with the hood up for shows or valve covers on an open-air build.
Motor Coater UV Resistance: Quick Facts
UV stable: Yes, formulated for continuous sun exposure.
Rated use: Exterior grade, holds color and gloss outdoors.
This makes Motor Coater a good match for parts that stay visible outdoors or under an open hood, not just enclosed engine bays. Because it is exterior grade, fading and chalking from sun exposure are not a concern the way they can be with interior-only coatings.
Frequently Asked Questions: Motor Coater UV Resistance
Yes, Motor Coater Engine Enamel is UV stable and designed to be exposed to sunlight consistently. It is an exterior-grade coating that holds its deep color and gloss when exposed to sun on a regular basis.
Motor Coater is formulated as an exterior-grade, UV-stable coating, so it resists the fading and chalking that can affect coatings not designed for sun exposure. It is a good fit for parts that stay visible outdoors or in an open engine bay.
Yes. Because Motor Coater is exterior grade and UV stable, it is suitable for parts that see regular outdoor sun exposure, not just enclosed engine bays. Proper surface prep still applies regardless of where the part is mounted.
Still have questions about Motor Coater? Contact us for help, or see the full Motor Coater Application Directions.
