Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
All Products
Paint Brush Black Poly Bristles Chisel Trim
Paint Brush Black Poly Chisel Trim - Produces Smooth Finish
1 Reviews
1
5.0
1
5
+Write a Review
Quality poly filled brushes at a disposable price. These paint brushes are made with black poly fill bristles for superior paint pick up and a smooth uniform finish. Features a chisel trim, plastic handle, and steel ferrule. Designed to produce a smooth finish for all of our 1K and 2K top coat paints.
Sizes & Quantity
1'' Brush
6 Pack - 1'' Brush
12 Pack - 1'' Brush
1 1/2'' Brush
6 Pack - 1 1/2'' Brush
12 Pack - 1 1/2'' Brush
2'' Brush
6 Pack - 2'' Brush
12 Pack - 2'' Brush
3'' Brush
6 Pack - 3" Brush
12 Pack - 3" Brush
Put me on the Waiting List
Price Each:
$0.00
Add to Cart
Details
Customer Reviews
Paint Brush Black Poly Chisel Trim Overview
100% Black Polyester Bristles.
Solid Plastic Handle. Very Sturdy!
Steel Ferrule (Holds the Bristles) Designed for a Consistent Finish.
Maintain Its Shape For Superior Control.
Ideal for flawless application of our
1K and 2K Top Coats
and
KBS Top Coater
, and
Shop Paint Brush Black Poly Bristles Chisel Trim
Email this page to a friend
Rating Snapshot
5 Stars
1
4 Stars
0
3 Stars
0
2 Stars
0
1 Stars
0
4 Stars
Clear Filter
Average Customer Ratings
5.0
Reviews Sorting
newest to oldest
oldest to newest
high to low rating
most helpful to least helpful
low to high rating
Smooth Finish
I use these brushed to brush on KBS Maxx to my brake calipers. The glossy finish came out super smooth and look pretty much like it had been sprayed.
Did you find this helpful?
Reviewed by: MackM from Columbus, OH on 12/1/2025
MackM
5
Customers Also Bought...
Preval Sprayer Kit
The Preval Sprayer Kit and Spray Gun is the perfect solution for applying coatings from KBS Coatings to small areas where control and quality of finish are important. The Preval Sprayer Kit is convenient and converts most paints into the ease of applying an aerosol paint.
(9)
More Info
SemperForce Black Nitrile Gloves
(21)
More Info
RustSeal is a single-component, ready-to-use rust encapsulating coating that permanently stops rust and prevents its return. It bonds to clean or lightly rusted metal and cures to a rock-hard, ceramic-like finish that resists road salts, fuel, and most chemicals without cracking, peeling, or chipping. Applied in thin coats with a minimum of two coats recommended, RustSeal delivers long-term rust protection on automotive frames, undercoatings, fuel tanks, trailers, and industrial metalwork.
(455)
More Info
(31)
More Info
(102)
More Info
(382)
More Info
KBS Top Coater
KBS Top Coater is a superior coating formulated to be brushed, rolled, or sprayed offering maximum coverage and professional looking results. KBS Top Coater is a direct to metal exterior grade coating that adheres permanently to steel and aluminum surfaces. KBS Top Coater is a very high solids paint that does not run or sag and gives at least twice the coverage of conventional paints.
(14)
More Info
Keep Shopping
All Products
Loading...
Add to Cart
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
