RustBlast will not disturb a fully cured coating. It is formulated to convert bare metal, not to strip or soften finished paint, powder coat, or a cured undercoating. You can spot treat exposed metal next to an existing finish without masking or removing the surrounding coating first.
| Affects cured coatings | No |
| Safe near painted panels | Yes, with normal care |
| Masking required | Not for RustBlast itself |
| Cleaning step | Water based cleaner only |
Treat the bare metal spot on its own. There is no need to strip surrounding undercoating or paint before applying RustBlast.
Spot Treating Bare Metal on a Coated Chassis
Chips, weld repairs, and modification spots often expose bare metal next to a chassis that already has cured undercoating or paint on it. RustBlast can be applied directly to that bare metal. It will not soften, lift, or discolor the cured coating around it as long as the coating has fully cured per its own product instructions.
What Has to Come Off First
Before applying RustBlast, the bare metal spot should be free of loose rust scale, oil, and grease. You do not need to remove or sand the surrounding cured coating. Focus prep work only on the bare metal area being treated.
Avoid Solvent Based Cleaners on the Cleaning Step
Use a water based degreaser such as KBS Klean to clean the bare metal spot rather than a strong solvent based cleaner. Aggressive solvents are more likely to affect nearby cured coatings than RustBlast itself.
Rinse Everything, Dry the Bare Metal Fast
After the RustBlast dwell time, rinse the treated area with water and dry the bare metal quickly to prevent flash rust. Wipe any overspray off the surrounding cured coating while it is still wet to avoid residue buildup.
