Apply RustSeal when the product, the air, and the surface are all between 55 and 82 degrees F (13 to 28 degrees C), with relative humidity in the 30 to 80 percent range. RustSeal is moisture-cured, so humidity matters as much as temperature: higher humidity shortens cure time, lower humidity lengthens it, and a damp surface can bubble the coating and ruin adhesion.
RustSeal Conditions: Quick Facts
Temperature: 55 to 82 degrees F
Humidity: 30 to 80 percent RH
Recoat window: 2 to 6 hours
Full cure: 24 hours
All three temperatures count. It is not enough for the air to be in range. The product and the surface being coated both need to be there too. Always allow products and surfaces to reach room temperature before prepping and painting.
Why Surface Temperature Matters
A cold frame rail in a warm shop is still a cold frame rail. Metal holds temperature far longer than the air around it, so a part brought in from an unheated garage can sit well below the air reading for hours. Coating a surface that is too cold slows the cure and hurts adhesion; coating one that is too hot flashes the solvent off before the film can flow out and level.
Humidity and Moisture Cure
RustSeal cures by absorbing moisture from the air, which is why it forms such a hard, non-porous shell. The ideal range is 30 to 80 percent relative humidity. Do not apply RustSeal in rainy or humid conditions where the surface cannot be kept dry, and never in thick or heavy coats: a heavy coat skins over on top and traps solvent gas underneath, which shows up as surface bubbling.
Frequently Asked Questions: RustSeal Application Conditions
RustSeal is dry to the touch with no fingerprint in about 2 to 6 hours, and reaches full cure at 24 hours. Because it is moisture-cured, those times move with conditions: humid air shortens the cure and dry air lengthens it. Wait the full 24 hours before top coating, before putting the part back into service, and before judging the final sheen.
Apply RustSeal when the product, air, and surface temperatures are all between 55 and 82 degrees F (13 to 28 degrees C). The same 55 to 82 degree range applies to the RustBlast step earlier in the system.
Recoat once the previous coat is dry to the touch and leaves no fingerprint, typically 2 to 6 hours depending on temperature and humidity. If more than 8 hours pass, wait a full 24 hours and lightly scuff the cured coat with a 320 grit green scouring pad before the next coat.
Avoid it. RustSeal is moisture-cured and should be applied within 30 to 80 percent relative humidity. A damp surface can bubble and cause improper adhesion. Humid conditions also shorten cure time, which gives you less working time than you may expect.
Store RustSeal in a cool, dry place. It may even be refrigerated, but it must be brought back to room temperature before you use it again. Unopened RustSeal has a shelf life of 2 or more years; once opened, plan on about 6 months stored cool and dry.
The top layer skins over and traps solvent gas underneath, which causes surface bubbling. Apply a minimum of 2 thin covering coats at about 2 mils each for general applications, and a minimum of 3 thin coats for marine or industrial work. Never apply an additional coat before the prior one is dry to the touch.
Working in marginal conditions? Read the full RustSeal directions or contact us before you start.
