RustSeal is an industrial-grade, single-component (1K), high-solids rust preventive coating. Designed with advanced color formulations, it provides an airtight, waterproof seal that stops oxidation and corrosion at the source.
Whether for automotive, industrial, or home use, RustSeal is the most permanent and cost-effective solution for protecting metal surfaces in any environment.
Unlike temporary treatments, RustSeal locks out water and air, ensuring oxidation cannot take hold. Satisfaction guaranteed!
View the RustSeal Color Guide for help choosing the right finish.
Gloss Levels: Galvanized (30%), Satin Black (70-75%), Gloss Black (85-95%), Other Colors (75-85%)
Need A Long Term Storage Solution for RustSeal?
KBS Paint Saver is a proven paint preserver that allows user friendly long term storing of RustSeal in the original can. +More Info
Theoretical coverage at 2 mils dry film thickness is 400 sq.ft. per gallon.
Recommended thickness of at least 4-5 mils dry film thickness requires at least two full coats.
For marine type applications or applications where the surface is consistently exposed to water, at least three coats is recommended.
Material losses during mixing and application will vary and must be taken into consideration. Please expect up to 30-40% less coverage on bare wood, rough, or sandblasted surfaces.
A comprehensive guide to identifying and stopping corrosion permanently.
Watch RustSeal withstand extreme stress without cracking or peeling.
How to prepare surfaces before body work to prevent future rust bubbles.
Learn the best spots on your vehicle to apply rust protection.
A step-by-step video on removing rust and painting mower decks.
Why RustSeal’s formulation remains the industry standard.
5.0
