Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
All Products
Schutz Underseal Spray Gun & 48-inch 360-Degree Spray Wand
4 Reviews
4
5.0
1
5
+Write a Review
The Schutz Underseal Spray Gun & 48-inch 360-Degree Spray Wand is ideal for applying KBS Bed Liner, KBS UnderCoat and KBS Cavity Coater as well as other Corrosion Inhibitors, Cavity Waxes, Bed Liners, and Undercoatings.
Add Empty Dome Quart Can - Used With Schutz Underseal Spray Gun
Yes
No
Put me on the Waiting List
Price Each:
$30.00
Retail Price:
$39.00
Your Savings:
$9.00
(23%)
Add to Cart
Details
Customer Reviews
Schutz Underseal Spray Gun & 48" 360 Degree Spray Wand Overview
Pressure Range: 45-150 PSI
1/4" NPT Inlet
Fits Standard US Dome Style Quart Cans
Made of Nickel Plated Aluminum for Durability
Smooth Trigger Action for Applying Coatings in Even Layers
Adjusting Screw for An Adjustable Spray Pattern
Specially designed for rustproofing auto bodies.
The Spray Tip of the Spray Wand requires just a 3/8" hole
The KBS Schutz Underseal Gun is designed to spray
Cavity Coater
and Cavity Waxes in hard to reach areas to provide rust protection.
KBS UnderCoat
and undercoatings with the ability to adjust the texture of the sprayed finish.
Complete with adjustable nozzle which can be set depending on viscosity of liquid or coating being applied.
Very Easy To Clean.
NOTE:
The included Spray Wand Attachment is designed to spray
Cavity Coater
and other thin, viscous coatings. Thin
Cavity Coater
30-50% with Mineral Spirits as needed. The included Spray Wand Attachment is
NOT
designed to spray
KBS UnderCoat
or other thicker in viscocity coatings.
Schutz Underseal Spray Gun & 48" 360 Degree Spray Wand Contents
Flexible extension probe (48") with 360 Degree Spray Tip (designed to spray
Cavity Coater
and other thin, viscous coatings)
Schutz Underseal Spray Gun & 48" 360 Degree Spray Wand Features
Working Pressure Range: 45 to 150 PSI
Air Flow Consumption: 13.5 SCFM (with spray nozzle)
Air Flow Consumption: 6.5 SCFM (with extension probe)
Shop Schutz Underseal Spray Gun & 48-inch 360-Degree Spray Wand
Email this page to a friend
Rating Snapshot
5 Stars
4
4 Stars
0
3 Stars
0
2 Stars
0
1 Stars
0
4 Stars
Clear Filter
Average Customer Ratings
5.0
Reviews Sorting
newest to oldest
oldest to newest
high to low rating
most helpful to least helpful
low to high rating
Flawless
Products worked great with no flaws. We’re able to get multiple units done in 1 day. Great product
Did you find this helpful?
Reviewed by: Lee from Wanatah, In on 3/24/2025
Lee
5
Undercoating and the Shutz gun
Took me part of a quart before I understood how to set the gun/pressures. But, very easy to set-up and spray. Results LOOK great! I don't know about the sound-deadening, but if it is equal to the look, it will be great! I sprayed at 60 degrees outside temp, at 50psi and material at about 34%. All in, this product is cost effective, easy to spray, looks great and I believe it will be effective at sound deadening!
2 of 2
Found Helpful
Reviewed by: TonBon from Jamul on 3/6/2023
TonBon
5
Great company
This company still understands customer service, which is above and beyond the fact that their coatings are just awesome.
2 of 2
Found Helpful
Reviewed by: Tug from Rollinsville, CO on 8/29/2022
Tug
5
Great Gun For The Price
I use Cavity Coater to seal the inside of my tubular artwork. This gun works great and the price was very affordable.
2 of 3
Found Helpful
Reviewed by: Clear Art from Des Moines, IA on 11/17/2021
Clear Art
5
Customers Also Bought...
Cavity Coater
Cavity Coater is the perfect solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating designed for long term protection on all metal surfaces. Cavity Coater provides a self-healing film which provides incredible rust protection on hard to reach areas.
(47)
More Info
KBS UnderCoat - Solvent-Based Rubberized Undercoating
KBS UnderCoat is a superior rubberized paintable undercoating that provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
(21)
More Info
KBS UnderCoat - Waterbased Asphalt
This VOC friendly waterbased undercoating provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
(3)
More Info
KBS UnderCoat - Solvent-Based Asphalt
This superior undercoating provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
(14)
More Info
SemperForce Black Nitrile Gloves
(21)
More Info
(31)
More Info
Keep Shopping
All Products
Loading...
Add to Cart
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
