Product Directions and Tech Data
Product FAQs
KBS Instructional Videos
Contact KBS Coatings
KBS Coatings Safety Data Sheets (SDS) are free PDF downloads, one for every paint, coating and chemical we sell. Find your product below and open its sheet. You do not need to fill out a form or give us an email address. For a chemical emergency, call InfoTrac 24 hours a day at 1-800-535-5053.
Find Your Product's SDS
Products are grouped by type. The product name opens its product page, and the download link opens the SDS as a PDF in a new tab.
Rust Prevention, Surface Prep and Primers
Topcoats and Clear Coats
Engine and High Temperature Coatings
Undercoating and Cavity Protection
Bed Liners
Fillers and Repair
Thinner and Supplies
Chemical Emergency Information
Directions and Technical Data
An SDS covers safety. For how to prep, mix and apply a product, see its directions and technical data on the Application Guides and Product Directions page, or browse project walkthroughs in the Application Guides.
Frequently Asked Questions About KBS Safety Data Sheets
A Safety Data Sheet is a 16-section document the manufacturer writes for each chemical product. It covers the product's hazards, safe handling and storage, protective equipment, first aid, firefighting, spill cleanup, disposal and shipping information. Employers keep SDS on hand so workers can read them, and anyone using the product can use them to work safely.
No. Every SDS on this page opens as a PDF you can read, save or print right away. You do not need to fill out a form or give us an email address.
Call InfoTrac, our 24-hour emergency response service, at 1-800-535-5053 in the US and Canada, or +1-352-323-3500 from other countries. For a medical emergency, call 911 first. Have the product label or SDS in hand when you call.
Yes. An aerosol contains propellant, so its hazards differ from the canned version of the same product. Use the sheet listed for the aerosol, such as BlackTop Aerosol or Motor Coater Aerosol.
A kit is a set of separate products, and each one has its own SDS. For a Tank Sealer kit, use the sheets for KBS Klean, RustBlast and Gold Standard Tank Sealer. For KBS MAXX, there are sheets for the base, the activator and both together.
The revision date is printed on each sheet, and this page always links to the current version. If you saved a copy a while ago, download it again from this page.
No. An SDS covers safety: hazards, protective equipment and emergency steps. For how to apply a product, use its directions and technical data on the Application Guides and Product Directions page.
Our SDS are published in English. If you need something else, contact us and tell us which product and what you need.
Still have questions about a KBS Safety Data Sheet? Our technical team is ready to help.
