Rust Prevention Paints That Go Directly Over Rust
RustSeal is a single part, 100% non-porous, ready-to-use, high-solid content, rust preventive coating, that is strengthened by exposure to moisture. RustSeal is impervious to road salts and most every chemical.
RustSeal flows out to a beautiful, rock-hard, tough coating that is tough to chip or scratch. These exceptional properties make RustSeal specifically formulated to prevent corrosion and stop rust.
RustSeal completely seals metal surfaces, blocking all the pores and preventing penetration of moisture, oxygen, and water vapor.
Unlike other corrosion treatments, RustSeal is an enhancement that lasts.
Water and air are locked out — oxidation, the precursor to rust, cannot take hold.
RustSeal is available in Gloss Black, Satin (OEM) Black, Silver, Grey, Oxide Red, Safety Green, Safety Blue, Safety Yellow, Galvanized, and Cat Yellow. Try some today…you’ll be amazed!
- ✓ CAN BE APPLIED DIRECTLY OVER RUST!
- ✓ SEALS & ENCAPSULATES RUST AND POROUS SURFACES
- ✓ APPLY BY BRUSH, ROLLER, OR SPRAY
- ✓ SUPER STRONG AND FLEXIBLE — HAMMER TOUGH!
- ✓ HIGHLY RESISTANT TO MOST CHEMICALS
- ✓ COMPATIBLE WITH ALL PAINT SYSTEMS
- ✓ ALL COLORS ARE COMPLETELY NON-POROUS
RustSeal — Stop Rust Paints and Rust Prevention
(457)
$126.00
(39)
$200.00
(2)
$72.00
(2)
$72.00
(158)
(8)
$27.00
(133)
$63.00
(11)
$60.00
(13)
$102.00
(61)
$135.00
(2)
$117.00
(4)
$162.00
(1)
$162.00
(9)
$177.00
(45)
$137.00
(30)
$80.00
(27)
$60.00
(2)
(22)
$47.00
(3)
$47.00
(2)
$47.00
(1)
$47.00
(1)
$72.00
(1)
$72.00
(2)
$72.00
(1)
$72.00
(1)
$72.00
(2)
$72.00
(1)
$72.00
(1)
$72.00
(1)
$72.00
(1)
