Yes, KBS Gold Standard Tank Sealer can be used on air compressor tanks. Prepping and sealing an air compressor tank is a common application for the KBS Tank Sealer System, and it stops the condensation rust that eventually causes leaks.
Most air compressor tanks develop rust over time from the condensation that forms inside the tank as compressed air cools. That rust can eventually eat through the tank wall and cause a leak, so many owners prep and seal the inside of their compressor tanks to stop the problem before it starts.
Use the same KBS 3-Step System as any other steel tank: clean with KBS Klean, etch with RustBlast, then seal with Gold Standard Tank Sealer.
Frequently Asked Questions: Tank Sealer on Air Compressor Tanks
Still have questions about sealing your air compressor tank? Contact us for help.
