Use KBS Klean full strength, 1 part hot water to 1 part KBS Klean, when cleaning the inside of a tank. The 10 to 1 dilution is for most other cleaning jobs, but tanks need the maximum cleaning power that full strength provides.
Why full strength for tanks: Tanks typically require the maximum cleaning power available, so full strength, 1 to 1 with hot water, is recommended over the standard 10 to 1 dilution used for lighter cleaning jobs.
Frequently Asked Questions: KBS Klean Dilution Ratio
Use KBS Klean full strength, 1 part hot water to 1 part KBS Klean, when cleaning the inside of a tank. The 10 to 1 dilution is for most other cleaning applications, but tanks need the maximum cleaning power full strength provides.
Still have questions about tank cleaning ratios? Contact us for help.
