It is always best to do all three steps of the KBS Tank Sealer System, KBS Klean, RustBlast, and Tank Sealer, when the ambient and surface temperature are above 55 degrees Fahrenheit.
Tank Sealer System Temperature: Quick Facts
Minimum: 55 degrees F
Most effective range: up to 80 degrees F
Warmer is better: KBS Klean and RustBlast are more effective when the ambient air and surface temperature are warmer, up to about 80 degrees Fahrenheit.
Frequently Asked Questions: Application Temperature
All three steps, KBS Klean, RustBlast, and Tank Sealer, should be done when the ambient and surface temperature are above 55 degrees Fahrenheit.
Yes. KBS Klean and RustBlast are more effective when the ambient air and surface temperature are warmer, up to about 80 degrees Fahrenheit.
Application below the 55 degree F minimum is not recommended. Cold ambient or surface temperatures slow cure and reduce the effectiveness of KBS Klean and RustBlast, so wait for warmer conditions or work in a heated space before starting.
Still have questions about application conditions? Contact us for help.
