Yes, the KBS 3-Step Tank Sealer System is absolutely ideal for new tanks. If you leave a new tank uncoated, it will eventually rust, leaving you with clogged fuel filters and injectors.
New Tanks: Quick Facts
Works on new tanks: yes, recommended
Prep still required: yes, KBS Klean and RustBlast
Common misconception: New tanks made of new steel are very slick and not an ideal surface for Tank Sealer to stick to. KBS Klean and RustBlast are still needed to properly clean and etch the surface so Tank Sealer can bite in and adhere permanently.
Frequently Asked Questions: New Tanks
Yes. The KBS 3-Step Tank Sealer System is ideal for new tanks. If left uncoated, a new tank will eventually rust and clog fuel filters and injectors down the road.
Yes. New steel is very slick and not an ideal surface for Tank Sealer to grip. KBS Klean and RustBlast clean and etch the surface so Tank Sealer can bite in and adhere permanently, even on new metal.
Still have questions about sealing a new tank? Contact us for help.
