Yes, the KBS Tank Sealer System is used all the time to prep and seal up oil tanks. Be sure to prep the surface well, since any oil residue left inside the tank can affect long-term performance.
Oil Tanks: Quick Facts
Works on oil tanks: yes, widely used
Key risk: leftover oil residue
Prep is the key with oil tanks: Any oil residue that is not cleaned from the inside of the tank could cause long-term performance issues with the sealer.
Frequently Asked Questions: Oil Tanks
Yes. The KBS Tank Sealer System is used all the time to prep and seal oil tanks. Be sure to prep the surface thoroughly, since leftover oil residue on the inside of the tank can cause long-term performance issues.
Thorough surface prep is critical. Any oil residue that is not fully cleaned from the inside of the tank before applying Tank Sealer can interfere with adhesion and cause premature failure.
Still have questions about sealing an oil tank? Contact us for help.
