Yes, you can reuse KBS Klean solution when cleaning a tank. Drain the used solution into a bucket and keep it until you can inspect the inside of the tank to verify it has been cleaned well. Some customers have reused the same solution to clean a tank up to ten times.
Reusing KBS Klean Solution: Quick Facts
Reuse: drain, filter, and reuse as needed
Typical reuse count: up to 10 cleanings per batch
Pro tip: Placing some nuts and bolts or a loose chain inside the tank, along with frequent shaking and rotation with the KBS Klean solution, helps knock away loose rust and contaminants.
Frequently Asked Questions: Reusing KBS Klean Solution
Yes, drain the used KBS Klean solution into a bucket and keep it until you can inspect the inside of the tank to verify it has been cleaned well. You can filter the solution as it drains into the bucket to remove rust and debris.
It depends on how dirty the inside of the tank is when you start. Some customers have reused the same solution up to ten times, filtering out rust and debris between uses.
Yes. Placing some nuts and bolts or a loose chain inside the tank, along with frequent shaking and rotation with the KBS Klean solution, helps knock away loose rust and contaminants.
Still have questions about cleaning your tank? Contact us for help.
