How to Paint a Rusty Farm Plow Without Sandblasting
Posted by KBS Coatings on 8/26/2026 to
How to paint a rusty farm plow without sandblasting: remove loose rust, prep the metal, seal it with RustSeal, and add a durable UV-stable KBS MAXX topcoat.
How to Restore an Engine Bay Without Removing the Engine
Posted by KBS Coatings on 8/14/2026 to
Restore your engine bay without removing the engine. Learn how to remove rust, prep metal, and apply durable coatings for long-lasting protection.
How to Brush Metallic Paint Without Streaks
Posted by KBS Coatings on 7/29/2026 to
Metallic colors look best sprayed, but they brush well with the right method. Learn why metallic flake streaks and how to brush KBS metallic colors smoothly.
How to Repair a Dusting Concrete Floor Before Applying a Long-Lasting Coating
Posted by KBS Coatings on 7/22/2026 to
A dusting concrete floor will peel any coating you put on it. Learn how to test, grind, repair and coat it with KBS RustSeal and KBS MAXX for a floor that lasts.
How to Seal a Rusted Galvanized Stock Tank (Even a Duck Pond) So It Stops Leaking for Good
Posted by KBS Coatings on 7/16/2026 to
A rusted galvanized stock tank doesn't need to be replaced. Learn how to clean, etch, and permanently seal it with KBS Klean, RustBlast, RustSeal, and BlackTop.
How to Protect a Battery Tray from Rust, Corrosion & Battery Acid
Posted by KBS Coatings on 7/14/2026 to
Neutralize battery acid, remove corrosion, and coat battery trays with KBS RustSeal for long-lasting, acid-resistant rust protection. Step-by-step guide.
How to Fix Hidden Rust in Rocker Panels, Cab Corners, and Body Seams
Posted by KBS Coatings on 7/1/2026 to
Rust behind rocker panels and cab corners is often worse than it looks. Learn how to inspect, repair, and permanently stop hidden rust with KBS RustSeal.
How to Prevent Mower Deck Rust
Posted by KBS Coatings on 6/17/2026 to
Stop mower deck rust with the KBS Coatings 3-Step System. Learn how to remove rust, prep bare metal, and apply RustSeal for lasting corrosion protection.
How to Get Any KBS MAXX Color in the Finish You Want
Posted by KBS Coatings on 6/14/2026 to
KBS MAXX colors don't lock you into a sheen. Topcoat any matte color with KBS MAXX Clear (Gloss), or any gloss color with Clear (Satin) or Clear (Flat) to get exactly the finish you want.
How to Repair Trailer Frame Rust So It Doesn't Come Back
Posted by KBS Coatings on 6/3/2026 to
Learn how to repair trailer frame rust so it doesn't return. Clean, treat, and seal with KBS Klean, RustBlast, and RustSeal for long-term rust prevention.
How to Handle Single-Component Moisture-Cured Urethane Coatings: Induction Time, Stirring Intervals, and Skinning Prevention
Posted by KBS Coatings on 5/29/2026 to
KBS MCU coatings like RustSeal, BlackTop, and DiamondFinish Clear need zero induction time. Learn correct stirring intervals, how to handle skinning, and pro tips for best results.
Best Clear Coat for Metal: Prep Procedures and Application Tips for Long-Lasting Protection
Posted by KBS Coatings on 5/21/2026 to
Find the best clear coat for metal and learn how to prep bare or rusted metal for a durable, UV-stable finish with KBS Klean and DiamondFinish Clear.
How to Clear Coat Taxidermy with DiamondFinish Clear
Posted by KBS Coatings on 5/8/2026 to
Learn how to clear coat taxidermy with DiamondFinish Clear using an airbrush or spray gun. Crystal clear, durable, UV-resistant protection for mounts.
How to Apply Bedliner to Your Jeep Floor: Prep, Seal, and Protect
Posted by KBS Coatings on 5/7/2026 to
Step-by-step guide: remove carpet, treat rust, and apply KBS Bed Liner to your Jeep floor for a durable, waterproof interior that holds up to real-world use.
How to Fix a Rusting Truck Frame (And Stop It for Good)
Posted by KBS Coatings on 5/4/2026 to
That flaking paint on your truck frame isn't just ugly — it means the rust underneath is spreading. Here's why spray paint always fails on frames, and the three-step system that actually stops it.
How to Fix Rust on a Truck Frame and Stop Rust for Good
Posted by KBS Coatings on 4/22/2026 to
Learn how to fix rust on a truck frame with KBS RustSeal, RustBlast, and Cavity Coater. Step-by-step prep, coating, and cavity protection to stop rust for good.
How to Fix a Rough, Faded, or Oxidized Water Slide - Restore Speed and Performance
Posted by KBS Coatings on 4/9/2026 to
A rough-feeling water slide is usually caused by fading, oxidation, and surface wear breaking down the original gelcoat, creating drag and slowing riders. Restoring a smooth, high-performance surface requires proper cleaning, preparation, and
How to Paint a Motorcycle Engine So It Doesn't Peel, Flake, or Burn Off
Posted by KBS Coatings on 3/25/2026 to
Get a durable, professional finish that won’t peel, flake, or burn off. This step-by-step guide shows how to properly clean, prep, and paint a motorcycle engine using the KBS Motor Coater Kit.
How to Paint an Axle Housing the Right Way - Prevent Rust and Peeling
Posted by KBS Coatings on 3/11/2026 to
Rusty axle housing or peeling paint? Learn how to properly refinish an axle housing to stop rust and prevent paint chipping and peeling. This how-to guide covers cleaning, rust treatment, and coating for durable, long-lasting protection.
How to Repair & Stop Car Floor Pan Rust | The Ultimate DIY Guide
Posted by KBS Coatings on 2/25/2026 to
Don't let floorboard rust ruin your classic car. Learn how to identify, repair, and permanently stop rust in your car's floor pan using the professional KBS 3-step system. Covers surface rust, structural rot, and when to weld vs. use epoxy putty.
How to Seal a Metal Fuel Tank Inside and Out to Stop Rust and Extend Its Life
Posted by KBS Coatings on 2/12/2026 to
Learn how to seal a metal fuel tank inside and out to stop rust, prevent fuel contamination, and extend tank life using KBS Tank Sealer Kits and RustSeal.
Posted by KBS Coatings on 1/28/2026 to
Prevent cracking, peeling, and rust on your suspension springs! Learn how to prep and paint coil & leaf springs using the KBS 3-Step System for a long-lasting, flexible finish. Read more→
Posted by KBS Coatings on 1/26/2026 to
KBS RustSeal outperforms Glyptal as an engine internal coating. Seals porous castings, resists oil and fuel, and cures permanently. See how engine builders use it during rebuilds.
How to Paint Rusty Exhaust Headers So the Finish Won’t Crack, Flake, or Peel
Posted by KBS Coatings on 1/14/2026 to
This in-depth guide explains why header paint peels and shows how proper prep, high-temperature coatings, and correct heat curing deliver a durable, long-lasting finish that won’t crack, flake, or burn off under extreme heat. →
Posted by KBS Coatings on 12/31/2025 to
Learn how to paint aluminum wheels for long-lasting adhesion. This guide explains proper prep, application, and durability using KBS MAXX wheel paint.
What’s the Most Durable Way to Seal Wood Exposed to Heavy Use and Harsh Conditions?
Posted by KBS Coatings on 12/18/2025 to
Polyurethane swells and epoxy cracks on wood that takes real abuse. Learn how to seal trailer decks, workbenches and shop floors with KBS RustSeal.
How to Stop and Prevent Rust on Steel UTV Skid Plates
Posted by KBS Coatings on 12/5/2025 to
Steel UTV skid plates rust fast once the coating is gouged. Stop it with KBS RustSeal, then armor the plate with KBS Bed Liner or KBS Bed Renu.
Posted by KBS Coatings on 11/19/2025 to
Seal a wood shed floor against moisture, rot, and pests with KBS MAXX. Step-by-step prep, sealer coat, coat count, cure times, and a non-slip additive method.
Posted by KBS Coatings on 11/5/2025 to
Protect your dock from costly rust damage and corrosion with this step-by-step guide. Learn how to clean, prep, seal, and finish steel and aluminum docks using KBS Klean, RustBlast, RustSeal, and KBS MAXX for lasting durability and a professional finish.
A Proper Body Repair Method That Keeps Rust from Coming Back
Posted by KBS Coatings on 10/27/2025 to
Rust often returns after body repair because corrosion was never fully neutralized. Learn the full KBS rustproofing method: clean, treat, and seal with RustSeal.
How to Prevent Boat Trailer Rust: A Step-by-Step Guide | KBS Coatings
Posted by KBS Coatings on 10/8/2025 to
Rust not only makes your trailer look bad but can also compromise its structural integrity. This guide will show you how to stop existing rust and prevent future rust on your boat trailer using the KBS Coatings Ultimate Frame Coater Kit.
How to Stop Rust on a Steel Fence and Make It Look New Again
Posted by KBS Coatings on 9/24/2025 to
Learn how to stop rust on a steel fence, choose Rust Converter or RustSeal, prepare the metal correctly, and protect the new finish with a UV-stable topcoat.
How to Spot Treat Undercar Rust Before Winter | Rust Converter & RustSeal Guide
Posted by KBS Coatings on 9/12/2025 to
Protect your vehicle’s underside before winter. Learn how to spot treat rust on frame rails, floor pans, and suspension parts using KBS Rust Converter and RustSeal. →
How To Properly Open a Paint Can Preventing a Stuck Lid and How To Preserve Paint In The Can
Posted by KBS Coatings on 9/9/2025 to
Over the years, one of the most useful tips we give to our customers is how to properly open a paint can so it be sealed correctly. In the video, we show you how to properly open and close a paint can from KBS Coatings.
How To Seal my Plastic or Polyethylene Gas Tank
Posted by KBS Coatings on 7/22/2025 to
For rigid plastic tanks, our tank sealer products are used to seal the inside of the rigid plastic tank protecting against fuel weeping or leaking from the tank which tends to happen over time with plastic gas tanks.
How to Clear Coat Over Rust and Preserve the Patina Look
Posted by KBS Coatings on 6/6/2025 to
Want to seal rusted metal and lock in that weathered patina look? Learn how to prep and apply KBS DiamondFinish Clear coat over rust for lasting UV protection.
Do I Need to Use a Primer with High-Temperature Paint?
Posted by KBS Coatings on 3/13/2025 to
A common question that arises is: "Do I need to use a primer with high-temperature paint?" The answer primarily depends on exposure conditions. In many cases, using a high-temperature primer can enhance durability and corrosion resistance, ensuring a long-lasting finish. In this article we discuss when and how to use XTC and XTC Primer.
How to Prepare Metal for Painting Using KBS Klean and RustBlast for Superior Adhesion
Posted by KBS Coatings on 2/27/2025 to
Properly preparing metal surfaces for painting is essential to get the paint to bond and achieve a durable, professional-looking finish that doesn’t flake or peel. Here we will cover the steps to prepare metal for painting, with a focus on the use of KBS Klean and RustBlast.
How to Get Paint to Stick to Plastic: Step-by-Step Guide
Posted by KBS Coatings on 2/14/2025 to
Painting plastic surfaces can be a daunting task, often resulting in poor adhesion if not done correctly. See how KBS Klean, KBS SEP Self-Etching Primer and KBS FPP Flexible Plastics primer are used to prepare plastic for excellent adhesion of top coats.
Using Bed Liner on Rocker Panels, Doors, And Fenders for Protection
Posted by KBS Coatings on 1/24/2025 to
Off road truck, SUV, and Jeep body panels can be damaged by rocks, tree branches and other debris. Applying KBS Bed Liner on rocker panels, doors, fenders, and other body panels is an effective way to avoid this type of damage. See how it’s done.
Garage Floor Makeover Using RustSeal and KBS MAXX
Posted by KBS Coatings on 1/21/2025 to
Street Trucks highly recommends ordering RustSeal and KBS MAXX for any garage floor makeover. Terrific transition from old to new for the garage floor.
How to Remove Paint from Metal: Stripper, Blasting & Sanding
Posted by KBS Coatings on 1/17/2025 to
Compare paint stripper, media blasting, and sanding or wire wheeling to find the best way to remove paint from metal for your project.
Posted by KBS Coatings on 2/7/2024 to
Sealing the inside of an engine block addresses issues related to porosity, corrosion, and lubrication, and enhances to the overall longevity and reliability of the engine. Both KBS RustSeal and KBS Gold Standard Tank Sealer are excellent engine block sealer options. Here is how they are used.
Posted by KBS Coatings on 1/31/2024 to
The primary purpose of RustSeal, cold galvanizing compounds, and zinc rich coatings is to prevent rust. RustSeal prevents rust and corrosion in a very different way than zinc coatings. So, which is the best rust preventive coating?
How to Black Out Chrome Trim with Paint
Posted by KBS Coatings on 1/23/2024 to
Customers ask us how to black out the chrome trim on their cars and trucks in a way that they’ll get great looking, durable, and long-lasting results. BlackTop is an ideal black out trim paint for chrome. See how it is done.
Using Nonconductive Coatings as Part of an EV Conversion
Posted by KBS Coatings on 1/9/2024 to
Converting internal combustion engine powered vehicles to electric power is increasing in popularity. Electrical components must be mounted on non-conductive surfaces. You can make metal surfaces nonconductive with nonconductive coatings. See how RustSeal can be used as for this purpose.
Posted by KBS Coatings on 10/26/2023 to
By taking the proper steps to prepare and seal or prime the metal before body work (KBS Klean, RustBlast, RustSeal), future rust and possible pop off of the body filler can be prevented.
Posted by KBS Coatings on 10/17/2023 to
We always recommend using KBS Klean to clean a surface before coating or painting. We formulated KBS Klean as an alternative to solvent based cleaners and degreasers which notoriously leave a residue on the surface which can cause surface tension. KBS Klean rinses clean and does not leave a residue.
How to Paint and Seal a Concrete Floor with KBS Coatings
Posted by KBS Coatings on 9/28/2023 to
Compare RustSeal, KBS MAXX, DiamondFinish Clear, and KBS MAXX Clear as concrete floor paint. Prep steps, coverage rates, cure times, and which one to use.
Posted by KBS Coatings on 8/29/2023 to
For the ultimate and longest lasting rust protection, RustSeal is the best option after first preparing the surface with KBS Klean and RustBlast. KBS Rust Converter is a good rust preventer for use on completely rusted surfaces, but RustSeal will provide the longest lasting protection.
