Yes, you can heat cure XTC on a furnace exterior by firing the furnace. Bring the surface temperature up to 350°F, hold it there for 30 minutes, and the XTC will be fully cured. This guide covers the correct temperature, timing, and ramp for curing XTC in place on a furnace, wood stove, or similar exterior.
Shop XTC
Short answer: Get the furnace exterior surface to 350°F for 30 minutes. Bring the temperature up slowly, and let it come back down to room temperature slowly too.
Target Temperature and Time
XTC fully cures at approximately 350°F held for 30 minutes. On a furnace, this heat cure can be achieved simply by firing the furnace itself rather than using an external heat source. Ramp the temperature up to 350°F gradually rather than all at once, hold it at 350°F for the full 30 minutes, then let the surface cool back down to room temperature slowly as well. A slow, controlled ramp in both directions helps the coating cure evenly and avoids thermal shock to the finish.
Coat Sequence for an Exterior Application
For an exterior application like a furnace exterior, apply 1 to 2 thin, covering coats of XTC Primer before the XTC color coat. XTC Primer provides the rust protection that matters for a part exposed to outdoor conditions or a garage/shop environment, and it is rated to 1200°F on its own. Follow with your chosen XTC color, then complete the heat cure as described above. Review the full XTC Directions before you begin, which covers both XTC and XTC Primer application and cure steps.
Shop XTC Shop XTC Primer
Can I heat cure XTC on a furnace exterior by burning the furnace?
Yes. Get the furnace exterior surface temperature to 350 degrees F and hold it there for 30 minutes to fully cure XTC. Bring the temperature up to 350 degrees F slowly, then let it come back down to room temperature slowly as well.
Do I need XTC Primer on a furnace exterior?
For an exterior application like a furnace, apply 1 to 2 thin, covering coats of XTC Primer before the XTC color coat. XTC Primer provides the rust protection an outdoor or exterior-exposed part needs.
Conclusion
Curing XTC on a furnace exterior is straightforward: prime for rust protection if the unit is exposed to the elements, topcoat with XTC color, then fire the furnace to bring the surface to 350°F for 30 minutes, ramping up and back down slowly. Review the full application directions for complete surface prep and coat timing before you start.
Shop XTC Still Have Questions? Contact Us
